Driverack Pa Setup
Look for advice and settings on setting up the Driverack PA with A&H ZED 12FX mixer,Behringer EP2500 and 2 EV SX300s.
Do i need to use the compressor side of the PA and I take having only 2 speakers i dont need to worry about crossover but not sure on the subhonics ,any advice I would be greatful ,only been using just set up as custom speakers and custom amp but touched nothing else with the amp turned up full.
Thanks in advance
PS by the way ive 2 dbx 266XLs connected to the mic channels .
Thanks again.
Thanks in advance
Thanks again.
http://www.dbxpro.com/forum/viewtopic.php?t=959
Not able to check anything until Friday now so any info anyones got between now and then would be really helpful,I know its not the right section but also if anyone has any useful advice on the dbx266xl compressors been working quite well with them but still learning .
Thanks again .
I could not find the SX300s, but the -e- version have a -10 point of 50hz. Depending on how hard you push the speaker, set a BW24 at 50hz, up to 55hz, if needed.
Whole system compression in not usually recommended, but limiting is.
thanks again
