PA+ in Mono House with monitors
LouMiller
I have a question regarding using the PA+ in a mono house system with one side running the house and the other running the monitors.
I know you can unlink the EQ's and do both sides separately.But is there a way to use different settings on each side for crossover,subharmonic,delay,etc.?It appears to me these other parameters are global for both sides.
If you select Mono input and unlink EQ does it give you two separate mono inputs?
In the original driverack pa tutorial they show an advanced setup using the driverack this way but I could not find any specifics on it.
Lou
Lou
Also, If your using tri-amped system on the mains you will be SOL but if your using a biamp mains system simply use the left channel and the Hi and Mid outs and put the monitors on the Lo outs or better yet use the left channel in and the mid on the tops and the mono low left out for the subs for the mains. That gives the monitors 3 PEQ's as well as an auto eq 28 band GEQ from the right input.
Lou
So, you still haven't stated what your mains system is... fullrange? 2 way (tops and subs) three way? If the latter you cannot separate the mains and mono with the PA, or PA plus....IF however you have a t way (tops and subs) then you can separate the mains and monitors... so answer the questions, and give us the information requested in the READ ME FIRST BEFORE POSTING SECTION...
I think I am leaning toward just getting another driverack for the monitors.If I understand correctly,If my mains tops are on the left input and my monitors are on the right of the high output,I could auto eq them separately but everything else including AFS and the 3 band parametric would apply to both inputs.At least that is the way it looks to me in the diagram in the manual.Is that correct?
Lou
Lou
Dennis
Dennis
Many thanks,
Lou
