DRPA & amp configuration
I have a new DRPA I am going to configure it for 2x3 mono subs
My question is do I run my sub amp in paralle mode
with one cable going from the DRPA low output to the input on the amp and then
one cable going to my subs?
An unadvertized trick. When you select mono subs, both low outputs are summed, not just the one indicated. This allows you to run a line to each side of the amp if that is what you wish, instead of jumping the amp internally, or if you need to run lines to opposite sides of the stage.
QSC 1850HD to a pair of BFM t30 subs (4012HO eminance drvs)
8 ohms each
I just want to run one from each side of the amp
Dennis
So I would only have 1 cable going from the DRPA to the amp
I also need to make or buy a neutrik bridge adapter
What do you need a bridge adapter for? The 1850 has all you need built right in...On the switches make sure you you go 1,2,9,and 10 off (left) and all the rest on (right).
IF... using standard NL2 speaker cables.
IF... using the ch 1 speakon output (NL4 w/ 1+, 1-, 2+, 2-) AND piggy-backing the subs.
...Then he HAS to make a NL4(M) to NL2(F) (or NL4) adaptor using 1+ & 2+ to use his existing cables.
Personally I'd use the Speakon AND banana , or make a double speakon splitter, to even the power going to each sub with separate cables.
