DBX 160A Connections to Amp
Hello,
Should I connect a DBX 160A to a an Eden WT800B amp's mono Pre-EQ Effects Send/Return via TRS or TS cables. I am currently using TRS cables but wonder if I am hurting either the amp or compressor with these cables. Which is preferable? I will go out and buy what is appropriate.
DBX Input
Connector: 1/4 in. TRS and XLR, Floating Balanced; XLR: Pin 2 hot Phone: Tip Hot
Impedance: 40k
Maximum Level: +24dBu, Balanced or Unabalanced (Absolute)
CMRR: >45dB (any Frequency)
Detector Input: Connector: 1/4 in. TRS phone, Floating Balanced
Mono Pre-EQ Effects Send/Return
DBX Input
Impedance: 40k
