DriveRack Px, Mackie SRm 450 v2 and Unpowered Mackie s410S
Hello,
I am new to the driverack. I purchased a PX and would like to configure it with two mackie srm 450 v2 for the top end and 2 mackie s410s unpowered subs. Anyone done this configuration as yet. If so please let me know the settings you have employed under the custom setting for the sub.
Huh? Did you do the Auto EQ indoors? If so if you look at the product EQ curve (the 28 band GEQ) you will probably notice that the under 170 hz frequecies have some cut severely... usually the lowest ones.... that is room modes, and it stems from standing waves. You should actually -0- the frequencies below 170 hz and adjust those by ear.
I personally do not like the sub synth and it will tax your amps, but you should be able to get good results with the PEQ's and the GEQ.
hi flava. were you able to configure your PX with your system?
i need to configure my PX with 4 mackie sa1521z's and 2 s218s subs, powered by a single qsc rmx2450.
gadget: would you recommend the same for me? thanks!
Hi, Not sure just what subs the s218 is?... but if your trying to drive 4, 18" speakers with an RMX2450, you only have 750 watts per speaker. You might want to raise the HPF to 50 hz BW18...but yes, for the most part those would work fine for your setup.,
actually, i have six sa1521z's, and i thought of setting up two pairs as FOH and the third pair as "back of the house" so to speak. can the PX help further without contributing to echo problems and other reflection concerns? btw, the size of the venue is 168x54x14
thanks so much for replying!
