1st Timer PA+ System setup help
Just purchased the new Driverack PA+ but need help with settings since I use unlisted amps. can someone please help. here is my system setup:
Stereo 3-way
Highs - 1 Alesis RA300 to 2 HP940 Horns @ 8 ohms each (Stereo)
Mids -- 1 Samson SX3200 to 2 Dual cabs with (2) 15" Eminence Sigma Woofer @ 4 ohms each (stereo)
Lows - 2 Samson SX2800 to 1 Quad Wedge cab with (4) 18" Eminence Sigma (each amp bridged to 2 speakers @ 4 ohms)
Lows - 2 QSC PLX3402 to Quad Wedge cab with (4) 18" Eminence Kilomax Pro (each amp bridged to 2 speakers @ 4 ohms)
I have my Low outs split to the 4 amps
Any help is greatly appreciated
Dj King Tutt / ABC/Citadel Syndicated Radio
Stereo 3-way
Well I must warn you I am nothing if not blunt...and your probably NOT going to like what I have to say...
1. Eminence Kilomax... a power hungry monster...and NOT a good monster...same exact cabs as the Sigma drivers?
2. What cab designs? Proprietary? just some speakers thrown into a cab? modeled for the cab?
3. Your under powered
4. What IS a "quad wedge cab"?
so many questions...
And what about the mids?
2. Already had 4 Eminence Sigma Pro 18's so bought 2 Samson 2800 amps to match in bridge mode
was trying to match power without buying 2 more QSC amps and $ more kilomax woofers but I do plan on having all 8 kilomax 18's powered by 4 QSC PLX 3402 amps in the future
highs = custom (not sure of x-over settings but using EV HP940 Horns with DV1A 8 ohm drivers)
mids = Crown xls 802 (closest to Samson SX3200)
lows = QSC PLX II 3602 (closest to QSC PLX 3402)
1. Provide full frequency response of the cabinet/ driver, be it 41hz-120hz or 25hz -200hz ...etc...
2. Cabinet provides a load to the driver that keeps it from over excruding...( moving past the mechanical limits)
3. Most speaker plans come with "DRIVER RECOMMENDATIONS" Straying from that list is a bad idea...unless you are well seasoned in speaker design/building
Sorry , I can't help it.. those two drivers are TOTALLY different and they need totally different cabinet dimensions...Besides, placing them together (dissimilar speakers) causes problems of their own.
Highs - HP940 Horns-DH1A Drivers
Power Freq response: 500-20,000 Hz
Nominal Impedance: 8 ohms
Nominal dc Resistance: 4.5 ohms
MID SPEAKERS - EMinence Kappa Pro 12A
Nominal Basket Diameter 12", 304.8mm
Power Rating: Watts 500W
Music Program: 1000W
Resonance: 37Hz
Usable Frequency Range: 57Hz-2.8kHz
Sensitivity*** 97.1
Magnet Weight: 80 oz.
Gap Height: 0.375", 9.53mm
Voice Coil Diameter: 3", 76.2mm
LOW SPEAKERS - Eminence Kilomax Pro
Nominal Basket Diameter: 18", 457.2mm
Power Rating: Watts 1250W
Music Program: 2500W
Resonance: 32Hz
Usable Frequency Range: 33Hz-300Hz
Sensitivity*** 95.8
Magnet Weight: 109 oz.
Voice Coil Diameter: 4", 101.6mm
Sorry, Raising Arizona is one of my favorites.
"Everybody freeze and get on the floor!"
"Well..... Which is it sonny? You want us to freeze or get on the floor? Cuz if I get on the floor, I won't be freeze'n and if I freeze, I can't rightly get on the floor, cuz I'll be moving...so, which is it?"
Gadget, put all the Sigmas in the same box, etc and maybe add dampening, change the ports etc on the other?
Mids HPF 110hz LR 24
Mids LPF 1200hz LR 24
Subs HPF 45hz BW18
Subs LPF 110hz LR 24
PEQ Hi shelf 6db/oct slope @ 2500 hz +8-10 db (CD horn EQ)
Xover gain Subs +3, Mids -0- horns -10
Any chance of a picture or diagram of the subs? Or the construction plans or drawings, the manufacturer or site location? I'm curious of the design
