RTA Mic and Pink Noise Volume
I have been unable to get the Auto EQ to give the "performance level" message and move to the next step. I have done the method in the manuel, the outside method, and the new inside method. I have set the speakers (JBL Eon15/with two Eon subs run mono) to different levels and cannot get a RTA reading no matter what I do. Have gone all the way up to the point to where the guy who owns the speakers has ordered me to shut it down. Yes the RTA button is engaged. How load does it have to be to get it to work???????
Mike
Mike
1. Enter Wizard, select "Auto eq"
2. Follow the prompts..."press the mic button next to the mic input to enter the Auto eq sequence...
3. turn the rotory encoder clockwise to set the desired level (LOUD)
4. if you cannot get the Auto eq to indicate "TURN DOWN LEVEL" you need to check the mic cable...
5. once the desired level is set, press the [next] button and the sequence will begin
have you experienced this?
I have done all you have said.... entered the wizard, followed the prompts, pushed the RTA button, used two different RTA mics, different cables and still have not experienced a "turn down level" message and have not been able to proceed with the sequence.
The manuel says, "0db-6db typical," the picture in the manuel shows 18db, and I have turned mine up to 20db. REALLY load! Will this high volume of pink noise damage the speakers? Should it need to be this load? What is TOO load?
Thanks for your help,
M
As far as "how loud"? Just like the manual recommends... 0-6 is plenty (I've done much less).
2 RTA mics? What are they? Are they condensors? Do they work (when spoken into)?
Maybe the PX itself is not working properly cause I have tried multiple variations of mic placement and volumes with no success. ????????????
Will give it another go and if nothing happens will return unit for exchange.
Thanks again,,,,
Dennis
He has an e-mail link. If it has not changed you might try that to see what the conclusion was.
A thought. Could be that the mic input is not passing phantom power. You might check that. How much did you pay for the PX? If cheap enough a repair may still be warrented. Is it returnable?
I did send an email to Mike. As far as the mic input not passing phantom power, you are referring to the driverack mic input right? How could I check to see if it's passing phantom power?
Mark
Yes.
You'll need a volt meter.
This is from Shure. Is should be useful. The voltage may be different, just make sure that the voltage meets the minimum required to operate the mic. DBX specs 9-52 vdc.
QUESTION:
I have a Shure MX392 that works OK on one input of a mixer, but not on another input of the same mixer. I suspect the phantom power supply of the mixer, or the mic cable run that leads to the mixer. How do I test the phantom power voltage and current?
ANSWER:
For this example, we will assume the phantom power voltage is rated at 48 Vdc and the maximum phantom power current is rated at 7 mA, i.e., 48 Vdc supplied through a 6.8 kOhm resistor as per the DIN Specifcation 45 595, dated August 31, 1976.
First, measure the phantom power voltage:
1.Disconnect the mic cable from the mixer.
2.Set the Volt/Ohm/Amp meter to read from 0 to 50 volts DC.
3.Measure from XLR pin 2 to XLR pin 1. Note the voltage.
4.Measure from XLR pin 3 to XLR pin 1. Note the voltage. The DC voltages measured should be exactly the same - to the tenth of a volt.
5.Measure from pin 2 to pin 3. The DC voltage should be zero or nearly zero.
6.Reconnect the mic cable and make the same measurements at the microphone location, BUT with the microphone disconnected. The voltage results should be nearly identical to the readings at the mixer.
Second, measure the phantom power current:
1.Make these measurements at the microphone location, but with the microphone disconnected.
2.Set the Volt/Ohm/Amp meter to read from 0 to 100mA DC.
3.Measure current by connecting the positive meter lead to XLR pin 2 and the negative lead to XLR pin 1. The reading should be > 7mA.
4.Repeat the previous step using XLR pin 3 and XLR pin 1. The reading should be > 7mA.
If the voltage measurements and current measurements are not as described above, the mic cabling could be defective or the phantom power supply circuit in the mixer could be defective. In either case, the phantom powered microphone will not operate properly.
If screw terminals are used:
XLR pin 1 = ground
XLR pin 2 = audio positive/send
XLR pin 3 = audio negative/return
PS - please report back any and all info regarding the solution to your problem.
By plugging the RTA Mic into my mixer with the same lead I was using for the Auto EQ Wizard and applying power feed to the relavent channel, I quickly proved the RTA mic was OK by simply talking into it.
I then went back to the PX rack and started the the Auto EQ wizard again with no response from the MIc again.
However by pushing the RTA mic plug a little more firmly into the PX Rack RTA socket I was then able to complete the wizard. So I suspect a little wear and tear is the issue.
