Setting limiters
I have a new DRPA+
When setting the limiters, do I just go thru the different levels of overeasy or am I missing some other setting?
Do we have guidelines for the Threshold?
Direct me to existing if I need to do some reading
http://www.dbxpro.com/FAQs/process.php?cat=5
or my thread in our FAQ's
viewtopic.php?f=60&t=1488
Compression depends on a lot of variables, and is a personal thing...
When setting my gain structure the only way that I can get my amps to clip is the set the +4/10 db switch on the back to -10.
When it is set to +4 I can turn the amp attenuators all the way up and get no clip light on the amp
Same for both amps qsc GX5 & 1850HD
Is that acceptable?
Next question
My threshold lights seem to stay red when setting the limiters unless I set the threshold to a large negative number ex: -20
What am I doing wrong?
The 260 wizard likes the 1850 at only 35%(10 o'clock). We don't use the wizard's recommendation much around here, but they are usually in the ball park.
http://www.ureidj.com/product_1601S.aspx
I have the red led's just barley flickering on the mixer (channel gain, and master volume)
Do I need to have them on steady?
DPRA+ set to +4db.
The mixer has a max output of +20dbu.
The output meters register +5 (whatever that means).
The mixer has a non-defeatable "Output Protection Limiter" when the unit clips.
This is what I would try.
Speakers on but turned down the amps to 1/10th output (or less maybe).
Play the Pink noise source CD.
Bring up the masters until you hear the "OPL" kick in. Then dial back a tad until you hear it disengage.
The meters will register what the mixer does just before clipping.
Unplug the speakers.
Now you should be able to get the amps to clip.
Set the gain structure as described.
Set the limiters as described.
This should protect the speakers beyond the mixers protection circuit. (double protection)
R
Maybe it is too subtle to hear, or I dont know what I am listening for
I have another cheaper DJ mixer (numark ), that I am going to hook up and
see what sort of results I get with it. My tops sound great I am just not comfortable that I am
getting the limiters set right so I am afraid to crank them up too much.
Here is the output for my mixer spec page
AUDIO OUTPUTS (LEVEL/IMPEDANCE)
Master (Balanced) +2dBu/600 Ohms
You said that is was +20dbu, but that looks like +2dbu
I am a noob so its possible I am not looking in the right place
here is the link
http://www.ureidj.com/product_1601S_spec.aspx
Thanks for your on going help
What he wants you to try is to INCREASE the INPUT gain on the channel till you get clipping... (Level or Trim controls per channel in your case) if you CANNOT get sufficient gain to clip the mixer your source material/players need to be looked at.
I can get a clip light when I crank up the channel gain/trim
Should the channel clip light be lit up steady when setting my gain structure or just flickering
Some may use the "clip" light as a "you only have 3db of headroom left".
Some use the light as "you are now clipping".
Unless you call their tech support, you are better off just using the occassional lighting (for structure processes, not for real world usage).
Now when I take my system to a gig and RTA the room do I need to
reset my limiters, or are they uneffected?
Have to admit I am a little nervous about getting there and botching up my limiters and having
to start over under the gun.
But to the limiters when set shouldn't require a whole lot of attention. Especially if your watching your master meters on the board you'll know exactly how much headroom you have left...THAT is the way to protect your system.
When you talk about seeing activity of your limiters are you talking about the color LED's or the actual limiter
indicators when you hit the utility button.
So did you completely MISS my last post? :roll:
just making sure that I understand completely what is going on. You actually just made a profound statement that clears things up even more for me even more. Us noob's dont have a point of reference when using this type of equipment for the first time, so we are naturally unsure, even when the pros tell us how to do it. Thanks a bunch for your knowledge and keep it coming. I like the straight forward answers, I am the same way.
Cheers
If I increase the crossover gain on my subs do I need to reset my limiters?
The reason is that I can barley get my sub amp to clip when setting the gain structure
Is there any rule of thumb when setting the crossover gain? or is it trial and error
That said, yes increase your crossover gain for the subs.. this is normal since most non horn loaded subs are less efficient than the tops... generally by more then 3-5 db to the mids and more like 10-12 db to the horns...
Then if it makes you feel better reset the limiters...
R
