DBX DRIVERACK PA FOR PEAVEY SETUP
reservanortena
HEY THERE EVERYONE HOPE U CAN HELP ME WITH THIS. I HAVE A PEAVEY MIXER RQ2314 14CHANNEL, DBX DRIVERACK PA, 2 QSX RMX2450, 2 PEAVEY SP2 SPEAKERS, AND 2 PEAVEY SP218 SUBS. I WOULD LIKE TO KNOW HOW TO SET THIS UP WITH THE DRIVERACK AND HOW TO SET THE XOVER FREQUENCIES. I'VE BEEN USING IT FOR A FEW MONTHS NOW AND I STILL CANT GET THE PUNCH I WANT FROM MY BASS DRUM AND BASS GUITAR. PLEASE IF SOMEONE CAN HELP ME WITH THIS I WOULD REALLY APPRECIATE IT THANKS IN ADVANCED.
I have put a bi-amp article in the FAQ section...
45 (maybe 40)hz BW18 - 100hz LR24
Tops:
100hz LR24
You didn't say, but did you Auto EQ the system in the room you are playing in?
PS - It is not so much that you are "underpowering" the subs, but that you don't have system balance. It is probable that you need more poower to the subs to get balanced. It is possible that you don't need all the volume that the tops are producing and could turn their levels back. Lots of caviots here.
It's been my experience that there are 3 truths to front loaded subs...
1. a large motor structure with at least a 4" voice coil
2. sufficient power to drive it properly
3. A properly designed enclosure that protects the driver and lets it move some air
The thing about #1 is that a big driver with a 4" voice coil takes horsepower to get it moving... this speaker has a CONTINUOUS power handling RATING of 800 watts which means that a 1600 watt per channel (per speaker) is recommended, and 2400 watt instantaneous peaks allow good headroom... this means that the SP 218 should by all rights be offered 3200 watt program power with a dynamic capability well above that.
325 watts is barely enough to get those speaker cones moving. Now, if we were talking about a PV 118 cab that is a horse of a completely different color...and, unfortunately, with it's 3" voice coil... no matter HOW much power you throw at it you couldn't get the kind of sound your looking for...just ain't gonna happen...
Those GC and now SA guys are clueless... :?
Dennis
