Outputs from DRPA+
Fan
I have a DRPA+ with a Behringer 5000PM powered mixer pushing two Peavey 215's. My usage is for karaoke in my home. I have used the wizard for the DRPA+ to set up for the room (15' ceilings). My question is can I run a cable from the DRPA+'s Low ranage output to my Peavey 215's along with the cable from the High range to get a better bang on the low end?
Another possibility. I also have a BBE 462. Can I use the BBE 462 in line and get more low end?
I am sure that I am going to be told to buy a subwoofer and another amp. I am simply trying not to overpower my room.
Fan
Fan
Dennis
Thanks for the prompt response. I ran 1/4"xXLR out of my main out (R/L) on the Behringer to the input on the DRPA+ then the same type patch chord back to the "power insert" on the Behringer. Run my speaker wires (Speakon) to the Peavey 215's. Sounds great! Have I done something wrong?
Dennis
I suppose you could corner load the speakers (place them in corners) if possible and take advantage of some very peaky low bass extension...or as I said above use the PEQ's to boost the lows and cut the highs but that's really only a bandaid as I said.. but then I'm a bass freq and real subs are necessary for my sanity...
But, he is right.
If I add a Peavey 118 will I get better low end sound using the Mackie amp? Price is an object since this is basically for home use.
Thanks again for the info and support for the fine dbx products.
Do you EVER take your system out of the house?
Are you handy (basic carpenter skills)?
My ceiling height is 8' - 15' sloped.
Yes, from time to time I have some karaoke gigs for friends.
Let me say this about my carpentry skills, I could probably make an enclosure for a subwoofer for about twice what I can buy one for...LOL.
I do have an old speaker enclosure (Genz-Benz) that housed a 15" woofer, a mid and a driver. I could enclose the two smaller holes and add a 15" subwoffer easy enough. I am retired now, but I really don't have the time anymore like I did when I was working. I think I will stick with something I can buy. If that is where you were going.
Keep the ideas coming, my mind is not completely closed, just very short lived.
Gadget has designs in the "Read me first section" that you could probably build ( or have built) 2 for the price of 1 bought. Worth looking and considering.
