no sound
Suddenly lost all sound on a gig. Signal path good up to DRPA, good after it. Turned unit off then on, problem seemed to disappear. Works ok now. PA is moved two or three nights a week, unit is maybe three years old, in a rack case, handled fairly carefully, but plenty of miles, temperature changes, etc. Night in question, voltage at the outlet was about 119, ground was ok. Furman PL-8 power conditioner. What should I look for, what should I worry about?
Dennis
I have exactly same problem. The PA screen would go blank, and no sound would come out.
I had to power it off, and turn it back on.
This happened more frequently for no apparent reason.
From the replies, I think I should call the manufacturer and tell them the symptom.
Is there a different way to correct the problem? You know, to minimize the fixing cost.
gadget
