New speakers to configure. mackies/Yorkville
Monkey JuiceMonkey Juice Posts: 2
Hello I just upgraded from 4 mackie tops srm450-2 and 4-swa1501 subs to 2 Mackie tops sa1532z and 2 Yorkville Ls801p subs. The driverack 260 work really well for me with my previous system and was quite easy to configure. I noticed the Sa1532z are not listed. Is there a list of new speakers that have been added to the 260? If not, use the custom setting for both the tops and the subs and dive into the specs to see what the crossover settings should be. Has anyone had past experiences with these speakers and the 260? Any advice will be appreciated. I tried searching for any post for the mackie"s or the yorkville's with no luck. thanks
  • DraDra Posts: 3,777
    100hz using LR24 on both filters should be fine.
  • GadgetGadget Posts: 4,915
    No your speakers are not in the menu and I don't believe they are available, but thats not a problem since they are powered and fullrange..Simply set the highpass and lowlass as DRA specified and you'll be fine...
