DriverackPA+ for Monitors
I am setting up a DRPA+ for two stage monitors, (EV Sx200 passive) and powering them with a QSC RMX1450 that is set "bridged mono". Needless to say, there is only one mix.
I am planning to select the EV Sx300 speaker setting from the wizard because as far as I can tell, the specs are the same as the Sx200. I'll connect my mixing console to the left input of the DRPA+ and go to the amp from the left high output. Am I doing this correctly?
DeeDee
DeeDee
I am very new to setting sound and appreciate your advice and tips on how to do this...from scratch.
DeeDee
Yes, but there's no need to use the SX200 preset, just set the system up in the wizard and set a 2x2 (since that is the least that is allowed) and since it's monitors I would suggest a LPF of 60hz BW18 ... that is what I use and it works well...
