Home dbx User Forum dbx Archive Threads dbx Archive General Connectivity
Unable to Flash ZONE PRO 640m
spikyspiky Posts: 2
edited November 2009 in Connectivity
Followed all possible FAQ and reset documents. I'm able to connect to my 640m via ethernet or serial. Currently sitting at version 1.020. Would like to upgrade.
Computer: COM1 On-Board (not USB adapter)
OS: XP SP3
NET Framework: 1,2,3.5 (latest service packs)
I've installed the latest 1.11 flasher. However it detects my device as 1261 and it crushes with following errors.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index and length must refer to a location within the string.
Parameter name: length
at System.String.Substring(Int32 startIndex, Int32 length)
at ZpFlash.ZpFlash.Start()
at ZpFlash.ZpFlash.Flash_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2443
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
ZpFlash
Assembly Version: 1.1.2727.17165
Win32 Version: 1.1.2727.17165
CodeBase: file:///C:/Program%20Files/dbx%20Professional%20Products/ZonePRO%20Flasher/ZpFlash.exe
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
Networking
Assembly Version: 1.0.2727.17164
Win32 Version: 1.0.2727.17164
CodeBase: file:///C:/Program%20Files/dbx%20Professional%20Products/ZonePRO%20Flasher/Networking.DLL
dbxNetworking
CodeBase: file:///C:/Program%20Files/dbx%20Professional%20Products/ZonePRO%20Flasher/dbxNetworking.DLL
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Controls
Assembly Version: 1.0.2727.17165
Win32 Version: 1.0.2727.17165
CodeBase: file:///C:/Program%20Files/dbx%20Professional%20Products/ZonePRO%20Flasher/Controls.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Screenshots:
Any help would be great. Can't USE a ZC-3 for scene selection.
  • Hi spiky,
    There currently is no firmware update available for the ZonePRO"M" series (1.020 is the current version). The firmware update on our website is only for original ZonePRO (non-M) models.
