Help with DBX Drive Rack PA +?
I do live sound at a club and generally have 3 bands a night. I'm trying to get the best sound possible and wanted to know some good starting points in setting up my compressor and limiter. What should I set the threshold at? Any help would be appreciated.
B
B
are you considering compressing the whole mix? and if so why...(compression is usually best on a per channel basis)
what equipment are you using ?
have you done a gain structure?
The Idea with the gain structure is that you get all the equipment talking the same language...here:
viewtopic.php?f=61&t=959
we detail the whole setup process... including the gain structure...
(a little different gain structure is also in the back of the driverack manual)
as for the other driverack features we detail those and the tricks and tips here:
viewforum.php?f=60
there you will find this:
viewtopic.php?f=60&t=1488
compressing the whole mix 101...
I think if you have good bands that aren't all over the place then LIMITING might work best...
