speaker tunings now found in the pa+
does anyone know where i can find the speaker and amp tunings for the driverack pa+ specifically for the yorkville e15', yorkvilles 608's (more specifically the ucs1), and qsc 3602's. I have the old driverack pa without the usb port for upgrading firmware and would rather find the tunings online and manully input the tunings into my old pa rather than buying the new one.
That said you really don't need one unless you are bi-amping the tops... are you? If not then a simple HPF/LPF for the sub and a LPF for the tops and be well on your way....do you have the mic? If your going to bi-amp the tops there is a pretty good helper in the processor manual... a crossover plot...otherwise yorkville is useless when information about their products is concerned...especially where tunings are concerned...
The actual settings depend on application and system components...
amps/speakers...how many... bi-amp?
I have SW800 subs (808) so your 608's should work with the info below.
Full range set-up E12 only (Passive).
X-over: HPF
56 hz BW18 (E15's can change to 45hz if needed. I would not go below 50hz.)
PEQ: Hz Db Q
F1 75 +7 1.22
F2 315 -7 9.55
F3 800 -5 9.55
F4 DRPA settings, never went to the trouble to redo for 260.
2 Way Set-up E12 (Passive + sub)
X-over: Low
47.5 hz BW 24
100 hz LR 24
X-over: High
100 hz LR 24
OUT (This again, is the my DRPA setting and would probably LFP at 18K Hz BW 6 (or 12).)
PEQ High: Hz Db Q
F1 125 +5 1.22
F2 315 -7 9.55
F3 800 -5 9.55
F4 Same as above
PEQ Low: Hz Db Q (Yorkville)
F1 47.5 +4 2.03
F2 60 +2 5.71
F3 Same as above
F4 Same as above
and just to answer some generic question i use 2 plx 3402s to be exact......
i power 2 e15 tops and 2 ucs1 bottoms(both from yorkville)......1 speaker per channel...I run a simple 2 way system 1 amp for bottoms (low output) and 1 amp for tops (hi output)...and thats about it. the 3402 is powerful enough to run 4 tops....2 per side,,,,when i have larger audience i run an extra two tops
Isn't that like saying..."I drive a Volkswagon (more specifically a Lexus)"?
Dra really? I wish I would have known about this idea earlier (couldn't have) because two weeks ago I insulated my JBL tops which had absolutely nothing in them. I'm sure JBL did it out of saving costs -- but Yorkville does that? Are we talking about their subs? Tops?
After I stuffed my tops and re-ran the flattening session -- very little change on the Parametric settings. My alignment times changed a little.
The UCS1's are listed in the processor chart, so the tunings should work well. (or not)
I wonder about G's LabSubs? Any Subs????? Shoot -- I stuffed my Fanes full of it.
To Stuff OR Not To Stuff?
So I'm not surprised you are not seeing a major difference in the SMAART plots...but if you were doing distortion measurements I would expect to see a difference there...
I actually tried batting in the back chambers of the Labs and I ended up pulling it out... I do however put some of that acoustic tile (the matted fiberglass ceiling tiles... I pull the facing off and glue it with 3M 77 ) on the inside of the fane boxes to damp cabinet resonances further.
