Considering a Driverack PA+ but easy question about setup...
We are very new to PA's. Purchased a Yamaha MG24 board, two Crown XTi2000's, two SM15V monitors and two S115 mains. We currently have one crown powering the monitors, left and right, and one for the mains left and right.
Would the addition of the PA+ be a benefit to this system? We briefly had a Behringer Feedback destroyer and hated it. The manual was completely non-understandle (for me at least). The dbx equipment seems more automated with setup wizards, etc.
Would you recommend the PA+ for our simple Yamaha system? Or is there another box/system that would be an upgrade to manage two Crowns, two monitors and two mains?
Remember, on any response: you are dealing with a sound and PA neophyte....jc
The 260 will manage 2 signals and completely keep them separate. Plus, the GUI control (if you have a laptop) make things wayeasier to use. Download the Driveware in the training area. Also, do the tutorials.
For <$700 it is the way to go.
PS - You mentioned mains (L&R) and monitors (L&R). Mains must be mono and monitors limited to 1 mix.
As Dra said, it would require 2 driveracks to run stereo AND 2 monitor mixes...
I know these are braindead easy questions, but I am really new to this and am coming along slowly.
Dra, mentioned cheap speakers. I get it. We do get the feedback, thus the interest in some control with a DBX type box, on the gain from our voices/mics at mid level settings (about 12 o'clock). Sounds like these would seriously improve not only the feedback, but the sound of the speakers?
Are there any products from other companies that do this kind of control, or is DBX the only one. ie, does the price for a 260 have to be $700?...jc
What we said, Dra and I, is that with one unit you can run a stereo front of house, but the driverack has only 2 channels.. so, if you wanted to do mains AND monitors, you have 2 channels available... if you use one for the monitors, you will only have 1 for the mains... do you see the logic here? You could add another driverack and then have stereo mains and 2 monitor mixes but you can't with only one driverack...with only 2 channels.
So for stereo maind you would need to send the main outs through 1 driverack to the amp and the 2 monitor mixes through the other driverack and the other amp to the monitors...you cant send 2 signals through one channel and then split them after the driverack and have individual control of the 2 monitors... it don't work that way...
The 260 doesn't HAVE to be $700. You can buy used from Ebay, etc...
In case Gadget wasn't clear...
Driverack (whichever) has 2 channels.
FOH stereo (mains):
Left - 1 ch
Right - 1 ch
Monitors:
Gtr mix 1 - 1 ch
Gtr mix 2 - 1 ch
That's 4 total channels required. You need 4 channels of processing. The Driverack 4800 would do nicely. Yo, G. How much are those? $2000?
J, There are no easy solutions to your problem. At least that you want to hear. A single Driverack (assuming 2 monitor mixes AND FOH (of any kind) will not solve all your problems, but will solve 1/2 of them. Hard decision... make yourself sound good to yourself on stage, or sound good to the audience while stuggling against feedback etc on stage. It's a pickle. :?
We're always here to help.
I think our solution in the short run will be one Driverack for the monitors, then a second down the road for the mains. Our problems exist now only with the monitors...
Any thoughts from Gadget or Dra?....jc
The adding of an amp to use more monitors implies different mixes, but to simply add another monitor on the same mix doesn't require extra amps, at this stage.
Carry on.
I am currently running the mains off of one Crown, left and right, and two monitors off the other, left and right. We have a third SM15V sitting that I have wanted to put into play for either our bass or drummer, but I literally thought I needed another Crown to do so. Now I know to run the third parallel off of one of the two monitors.
Question though - when you program the Driverack PA + ....do you tell it, or does it care, that one side of the a monitor mix goes out to two monitors running parallel?
Thanks again for all the feedback. I think I am going to go with one Driverack for the monitors first, then a second down the road for the mains. I think doing so is still significantly cheaper than a 4800, though I know that would be optimal...jc
your golden!
Aren't you glad you mention having XTI's? Changed your whole world. As far as helping you with the amps, Gadget will have to do that. Good luck.
As long as the load impedance doesn't exceed 2 ohms stereo...you will be able to put however many monitors you want on each channel and the driverack, or the amps do not care...there is no difference...
In your case the yamaha's are 8 ohms so you could run as many as 4 per channel on the XTi as long as you stay in stereo.
In that case ALL 4 monitors would be on THE SAME MIX...as in Aux 2 make sure that monitors are run on a PRE FADER aux buss...
As Dra said the PA+ has a far superior auto eq algorithm.. and has more capability, and would be a good choice.
I could theoretically program the mains (EQ them) and then park that on the Crown for the mains. The DRPA+ could then be used "realtime" for the monitors. Remember, I am buying the unit to fight feedback for the monitors. Am I understanding this?
Also - my sense is the DRPA+ does many things, not just EQ and Anti-Feedback. Are all the functions from the unit able to be programmed and tranferred to the Crown's, or just EQ?...jc
Don't get caught up in the terminology. YOU are transferrer. Kind of like transferring a hand written note to a typewriter. You gotta manually do all the "transferring", like the set-up of DRPA+.
I think the processes available in the amps are...
Parametric EQ (not graphic, which is usually neccesary for monitors)
Pass filters (x-over)
Delay
Limiting (?)
These plus the graphic EQ & Feedback section are available on the DR.
I tend to agree with you that I would try the DRPA+ on monitors and see how it goes.
Correct, the XTi would then use the transferred settings for the mains...
Correct...the XTi has all the crossover, limiting, delay, and and peq needed for the mains...( a GEQ for guest BE (board engineers... a fancy word for mixer)
Do you have a laptop? you need to download Band Manager here:
http://hiqnet.harmanpro.com/downloads.php
It will allow you to set up and control the XTi amps different parameters .... and modify them FAR easier, and see what you are doing...
Yes I know this only poses a thousand more questions but you need to get a DR in your ahnds and read the setup onfo in the READ ME FIRST BEFORE POSTING SECTION...
The principle is the same, you don't have as many PEQ's or bi-amp (most likely) but the theory is the same...
Place the mic in the head position aimed at the monitor
use high precision
use the PEQ's for room mode and tweaking, a broad filter @ about 400 hz for the biggest problem 160 and 3k5 are other top candidates
HPF the monitors @ 120-150 hz ( I like 150...)
know your mic types...and monitor positions for instance hyper cardioid mics like the monitors at the 3 and 10 position where unidirectional mics like the monitor at the position the mic cord point to as in the base of the mic stand...
I currently have the monitors directly in front of the mics/mic stands. The mics are EV N/D 767a's and an Audix OM2. Before the DR PA, we had little to no feedback. In using the set up wizard with both the monitors and mains - we can hear a definite improvement in the vocals, but are not getting feedback?
Last - am I crazy: Is there no power buttom on the DR PA+? Am I supposed to plug it in to something like a power amp so they come on at the same time??..jc
The DRPA+ has a real time analyzer that will SHOW you where the feedback frequencies are...use it to determine where the problem is and put a PEQ on it...in a pinch the GEQ can help as well..
No power switch... I run a distro/power switch to the amp racks and the FOH racks...
