215 & 266XL. How do I connect them?
I am an audio novice at best and I have been given a project to assemble a PA system with the following components.
2 Shure wireless microphones
DBX 215 EQ
DBX 266XL Compressor
2 70v amp
I'm assuming that I will go from the mic to the compressor and then to the eq. Is that correct? What would be the purpose of the compressor in a system like this? Feedback suppression maybe?
Any suggestions will be greatly appreciated.
Andy
DBX 215 EQ
2 70v amp
Andy
So much much more info is needed about what the system comprises... ALL the info please!
Let me know if you need any other specifics.
Thanks for your help.
Andy
As for the rest of the program... does the TOA have a line out/power amp in port? See... if you had included the model # of the TOA I could have looked it up (perhaps) myself...
ALL the info...
podium?
what mic capsule? please don't say LAV..
the more specifics you give the better we can do for you... no detail is too small...
http://www.samsontech.com/products/prod ... &brandID=2
http://www.crestron.com/products/show_p ... 79&id=1570
http://www.crestron.com/products/show_p ... 77&id=1161
The microphones as designed were to use the following -
Shure SLX 14/85
Shure SLX 24/SM58
dbx 215 EQ
dbx 266XL
Qty 3 TOA A-712 (Room can be divided into 3 sections)
Qty 2 RDL ST-DA3 (3 output audio DA to distribute mics to the 3 TOA amps)
http://www.rdlnet.com/product.php?page=38
http://toaelectronics.com/amp0010.asp
http://toaelectronics.com/images/img_am ... ar_web.jpg
The TOA amp does have record out and preamp out.
The microphone levels will be set manually and the end user will not have access to the controls.
I hope this helps. Let me know if you need any other details.
and this:
So forgive me as I try and grasp the concept here... the later is already in place and the former they want incorporated into the system?
So we have already discussed the fact that compression and feedback are synonymous, add a LAV mic to the equation and the potential becomes pretty much a given...the addition of a carpet bomber (15 band GEQ) to the equation will do little to eliminate the potential. The Crestron HAS built in dsp which has EQ ... so are we stacking EQ's here as well, or are we NOT using the dsp onboard the system?
I must admit there are more questions here than answers...I'm afraid I still don't see a benefit in adding the EQ or compressor...and what does the original post with it's 6 items have to do now that we know that we have a much more complex system here...I mean as an admitted novice you might want to consult with someone with more knowledge on this type of system... someone with experience?
Lav mics make audio technicians lives hell on earth to begin with...the system needs to be tuned to the nuts and then some serious eq is needed for the lav itself...here your exacerbating this by covering a given space with both ceiling speakers and JBL control boxes which further complicates the issues here. I don't envy you the task at hand...Further, this is a hands on ( you really need to be able to touch and see and hear the concept in place in order to make sense of all this.. the room acoustics (most likely crappy to begin with) system implementation...(how it's deployed and hooked up) I don't know... maybe some pictures and a system block diagram would help us to see whats happening here...
Dennis? Dra? you following this at all?
+1 for pictures and a diagram.
Dennis
Thank you for the help. It is much appreciated. Next time I'll come here before the components are purchased.
Andy
You can get an account (free) @ photobucket, and then post a picture/drawing whatever there or email it directly to me @ tzone42@paulbunyan.net and I can post it ...but short of that I don't see this all coming together as a system...
Again, I very much appreciate your help.
The other system is the 2 wireless mics, they envision going through the dbx266 then the dbx215, then into 2, 1x3 switchers (for the three separate rooms) and then into the three TOA mixer amps and out to the ceiling mounted EV speakers...
Well, there is no doubt HOW they envision the thing hooked up...any chance of trading the 215 and 266 in on a driverack? the PX should work fine here... about the same money ... AND it will make your life SOOOO much easier..
FYI the driverack PX has
the 266xl comps
dual 28 band GEQ's
10 bands of PEQ's
auto eq
auto feedback suppression
auto gain control
full set of crossovers and filters
2 ins and 4 outs...
Measurement mic included...
This way you could use the auto eq to set the ceiling speakers up as flat as possible, then use the PEQ's to tune one channels outputs specifically for the LAV mic. set up the other for the handheld, then auto feedback suppressor the room with 6 fixed and six roaming filters.. this way you would actually have a prayer of pulling this off... The properly tuned speakers will help to maximize gain before feedback, the auto feedback suppression will help keep spurrious feedback in check as the LAV moves about the room..s... I can't see the 215 and 266 being able to accomplish this with any degree of consistency..
Get the driverack become a hero...
That's the way I see it... gentlemen?
A
Well, all you can do is hook it up and try... but usually you can bring new equipment back and trade it in for what you need... and believe me.. this isn't going to be a very user friendly system the way it's set up ...You will have an awful time with the LAV mic..
I suppose you could swap the comp and the EQ and use the EQ to get more signal level... but it's not the way I'd do it...Get the right stuff and do it right the first time..your never going to be sorry..
Dennis
You know it's tragic when salesmen that have no idea what they are doing sell a bill of goods to unsuspecting end users... in this case a dbx Zonepro 1260 would have done everything needed for this system ... all in one rack space. 12 inputs and 6 outputs and each room could have had it's own volume control...in the form of a ZC controller...the ceiling speakers in each room could have been controlled by the 1260, the JBL control could have been run off 2 outputs if necessary, and STILL had 1 output left...the system would then be password controlled with multi level security access and controlled by a laptop when changes were needed... even wifi could have been implemented so that a wireless tablet could have been used to walk the room and tune as you go...probably would have saved a LOT of money as well...three mixer amps? strange... very strange...
Somebody had a bug up their butt about controlling all of this with Crestron. I don't know if ZonePro is compatible but I think the SC series is. What you have laid out above is logical and is how I would do it but an AV installer/salesman is going to lean toward Crestron or similar because it is standard for their market. Arguing with them is an uphill battle.
Dennis
