newbie needs some help (DRPA, MACKIE, TAPCO and JBL)
dmenace
Hello folks
This is my first post here, and i hope i could get some help with setting up the crossover.
My setup is
Ecler (Dj mixer)
Driverack PA
Mackie FRS-1300
Mackie FRS-1700
Mackie FRS-1700
2X JBL JRX 215
Frequency Range (-10dB): 35Hz - 16kHz
Frequency Response: (3dB): 45Hz - 12kHz
Sensitivity (1W/1m): 100dB SPL
Nominal Impedance: 4 Ohms
4X Tapco 6918s Subwoofers.
Frequency Response (-10dB): 37Hz - 220kHz
Impedance: 8 Ohm
Power Handling (continuous): 450W
Power Handling (program): 900W
Sensitivity (1W/1m): 98dB SPL
Cheers
Dennis
My setup is
Ecler (Dj mixer)
Driverack PA
Mackie FRS-1300
Mackie FRS-1700
Mackie FRS-1700
2X JBL JRX 215
Impedance: 8 Ohm
Cheers
Dennis
Now that's some funny stuff there... man.. the gall of those guys...
Anyway the best way to help you is to steer you to some reading first...
Start Here:
viewtopic.php?f=61&t=959
then you'll need to check out the FAQ section:
viewforum.php?f=60
Browse the topics and you'll find a PLETHORA of info and tips and tricks...
For your system I'd suggest these points...
2x4
HPF 45hz BW18, LPF 100hz LR24
HPF 100hz LR24
1300 tops stereo HI outs
1700's Bridged mono 2 cabs per amp LOW outs
your under powered...
then follow the START HERE post...
35 hz too funny...
So if get it right, i should have the subs working between 45 and 100 hz and the tops from 100 hz and up?!
Another question that came to my mind is if i can hook up another rack of amps by using the mid outputs configured to deliver full range to the input of a second driverack? Might not be ideal but is it possible?
Im quite sure i will have some more questions so please bare with me :oops:
Cheers
Dennis
Dennis
Yes your sending the tops 100hz and up..
btw, im not sure im going there, just checking the possibilities in case it should happened. :oops:
Im using my soundsystem to throw some smaller techno parties, mostly outdoors so another thing that came to my mind when i thought about connecting the second rig was the delay as i wanted to place one stack of speakers in each corner of the dancefloor. (not sure but i think its called quadrophonic sound.)
Is there a good way to make it work with the delays using the driverack?
Dennis
Another question now as im struggling with the gain stuff..
My dj mixer in connected to the driverack and the switch on the back is set to +4.
On my mixer i can set the output sensitivity but im not sure what to choose.
I had it set to 0dBV until now, but don't know if thats what i should have
(OUT1: 0dBV(+3, +6 dBV soft configurable) / 600Ω)
Cheers
The outputs on the Low channel shows -30, sometimes jumps up to 0, and the high shows 0, sometimes up to 5.
When i choose the +3 on the mixer the driverack input dbu shows +5 and peaks on 10.
btw, just for curiosity I tried to make the driverack clip but i couldnt, even if i choose +6 and gained the mixer to the full and the mixer started to warn for overload.
the mixer is an Ecler EVO5 ,
http://www.eclerdjdivision.com/download ... l%20EN.pdf
The driverack wont even hit 15 dBu when the mixer is about to clip
So i guess im ready to go with the 0?
g
