DriveRack PA+( connections). HELPPPP!
Help me please to configure(to set) a system which contains:
1.Crown XLS 602 Amplifier 1 piece
2.Crown XLS 402 Amplifier 1 piece
3.JBL JRX 115 / 8 ohm speakers 4 pcs
4.JBL JRX 125 / 4 ohm speakers 2 pcs
5.JBL PRX 518 S subwoofer active 1 piece
6.Soudcraft Spirit Folio F1 1piece
7.DBX DriveRack PA+ 1 piece
How can i connect all these pieces (without full range)?
I'm thinking to connect all JRX 115 speakers with XLS 402 Amplifier on the DriveRack PA + exit, to connect the XLS 602Amplifier with JRX 125 speakers on the mid exit and PRX 518 S subwoofer to connect to low exit.
PLease help me to find a better solution to connect all these pieces with DriveRack PA +.
And how can i customize the mid exit ( i want to chose from DriveRack's library the amplifier's type)?
Thank you!
Thank you!
So be more specific, what do you see realistic combination's of these components being. What are they used for? (DJ/KJ/ livesound/theater)
Yes. I want to use all these speakers at the same time (DJ).
How can i chose on the mid exit the amplifier's type(without changing the others sets)?
So what are you looking for, a clock position for the amp? If you do a proper gain structure it won't matter because the amps sensitivity will be set then...
You would set up a 2x6 in the wizard, then set the HPF for the 2 sets of fullrange tops, the Hi outs don't have an LPF the mids do, set that to LR6 @15khz. Then set up the Low outs to run the subs.
