Just needing help on what to do.
I am wanting to get the DBX driverack PA. Currently I am using a Behringer Mixer at one show and a Peavey RsQ Mixer at the other. I am using 2 Peavey P2 and @ 2 Peavey P5 and a Peavey floor monitor. The Amps are 2 Peavey 1800's and a Peavey EQ. I also have a Yamaha Compressor for my wireless mics. I am wanting to upgrade. Suggestions are appreciated just don't know where to start
I think you need to give us more information about what you want.. If it's confirmation that the DRPA+ will make a difference, or work with those pieces then yes definately! If your wondering what settings to use then perhaps we should recommend you read the START HERE thread, and the pertinent FAQ's found here:
viewtopic.php?f=61&t=959
viewforum.php?f=60
To get the maximum benefit you will need to get a measurement mic, and it's well worth the extra expense. But give us more info as to what your looking for.
That is NOT a compatibility chart! That is simply a starting point for those speakers/amps. A basic setup we help with here EVERY day. SO simple in fact that we can have you up and running in less than 30 minutes once you have mastered the interface... (set the unit on the kitchen table and play with EVERY knob till you can navigate the units modules)
Yes it's compatible, and if your wondering, you can run mono and have the tops and floor monitors on the one driverack!
May I point out the READ ME FIRST section at the top of the opening page. There you will find the "Start here" thread:
and the FAQ section:
viewforum.php?f=60
For some good reading...
Other than that, you want and need a Driverack. I would suggest the DR260, if your budget allows ($700). It is far superior to the DRPA+, but the DRPA+ does have a fantastic Auto-EQ (says Gadget). Superior to the DR260.
