jbl sr4735 questions
looking to set up the following system with a driverack pa.
jbl sr4735
ev t-18 subs
my main questions r, do i need any delay between subs and 4735's.
i have heard about the phase of the 8" driver of the 4735. can someone explain this to me. jbl says u need to invert the driver. need explanation.. can anybody help with this system. thank u Gary.
these r the original 4735, not the a, or x series.
jbl sr4735
ev t-18 subs
There can be various reasons for inverting polarity between components in a speaker cabinet. Polarity has a different meaning than phase...the words are not interchangeable so what you meant to say was "I have heard about the polarity of the 8" driver of the 4735". As an example, if the crossover point between 2 components was comprised of 2nd order (12dB per octave slope) filters on both the low-pass and high-pass, the two components will automatically end up 180* out of phase with each other...it's the nature of 2nd order filters. Reverse the polarity on either component and the two of them will be in phase.
That is one reason for inverted polarity between components in a box. Don't fight it...don't fix it. It was designed that way.
Dennis
I would think you might want to delay the TOPS since the T18's are a "turbo" design that takes a tiny bit of time to get out. That and there is a 7.5 second propagation delay in the driverack (at least for the LR24 filter). I have the LABsubs and they have a 10.5 foot horn and I ended up delaying the tops about 18.2 ms.
The T18's however have a very tiny delay by comparison, similar to the EV S-181's which I have and I don't think are more then 4-5ms +propagation delay.. I think I use 8.5 -9ms total.
i would be triamping the system SO.....
the tunings say output 3-4 should be "INV" which is inverted polarity. this would be the 15" woofer correct??
1-2 would be subs
3-4 low mid 15"
5-6 mid high
the driverack pa "understanding the driverack" manual says the signal cable should have pins 2-3 swapped if any of the tunings call for an inverted polarity.
should i leave it alone or make a cable with pins 2-3 swapped?? what would u do?
Thanks for the help. Gary
P.S. I'd put Speakon connectors in those cabs and be done with it... If you need a schematic ..let me know..
Dennis
Sorry not very clear to this old fart..
As far as 2nd order filters go, the following explanation might be completely backward but the outcome is the same either way. A 2nd order hi-pass filter will result in a +90* phase shift and a 2nd order lo-pass filter will result in a -90* phase shift. This will put the two components being crossed over at 180* out of phase from each other. Reverse the polarity of either component and they are back in phase with each other.
Dennis
Look for a regression in the JBL product. It has ceased production in the USA and has moved ALL of it's manufacturing facilities to China. Suffice it to say...JBL will NOT be able to respond quickly to a crisis, and the quality will be suspect... until proven otherwise. 8)
All JBL has to do is keep their bills paid up with the Chinamen and they should be able to respond to a crisis a lot quicker than another set of companies that we are all familiar with.
Dennis
Gary
Thanks, Gary
