RE: EQ 101 FAQ
Here's a real world question.
How would you approach this situation?
Let's suppose you find a room that gives this result in the AFS.
Music High setting.
Filters at 175, 525, 675,690, 1.58k, 1.6k, 1.72k, 1.9k, 2.5k, 2.65k, & 8.5k. All reduced about 6-9db.
Assume a DR260, 9-band PEQ, AFS, & Notch modules available.
Music High setting.
I would need to see the room, but first impressions...
525, 675,690,- Room modes
PEQ 595 hz Q 2.035 -6.5
175hz- mode
PEQ 172hz Q 5.016 -7.0
1.58k, 1.6k, 1.72k, 1.9k, 2.5k, 2.65k,- reflections
PEQ 2K Q .0939 -6.5
Clear, rerun AFS, the notches are probably too narrow to help
How much above operating level and how many mics?
Live or DJ? How many mics?
So many qestions
I entered the info into the PEQ and the band from 400 - 4kwas reduced by an average of 4 db or so. That is a lot of lost sound. I assume that because of the closeness of several of them that the problem is fairly wide AND OTHER FREQS ARE NOT TOO FAR BEHIND in the same band?
Having said that, would it be better to use the same parameters but only reduce the gain to say... -3db and then let the AFS knock down the spikes of the room?
What is the notch filter's real use, if too narrow for this purpose?
