Home dbx User Forum dbx Archive Threads Zone Pro 1260/1261 Zone Pro 1260/1261 Software Control
Using ZonePRO Designer V3.0 with netbook
I have loaded and been able to use the ZonePRO GUI on my Toshiba netbook (NB305). However the bottom of the program scene window is cut off. So is the configuration wizard window. I can move the window up with ALT + spacebar, but it drops back when I press enter to exit. I have tried different resolutions. I also moved the toolbar to be vertical on the side (this helped), but still don't get the full window. Any suggestions?
  • GadgetGadget Posts: 4,915
    If you've gone to the "display properties" and adjusted the screen resolution and you STILL can't get full screen, I have no further ideas...Maybe Mike does I'm PM him.
  • mikejoeydbxmikejoeydbx Posts: 134
    Hi joecoolaudio,
    Make sure your DPI setting is set to 96. This setting should be located in Control Panel>Display>Settings>Advanced>General. Also, for now, you may be able to "Auto Hide" the Windows toolbar to be able to see all the buttons.
    Hope this helps.
