EQ settings
recrec Posts: 44
edited March 2010 in PA General Discussion
Can I make EQ changes on my DRPA+ real time, or do I need to turn the volume down make the change,
save settings then turn the volume back up?
  • GadgetGadget Posts: 4,915
    Nope, it would be pretty useless if you couldn't EQ in real time... Only caveat is that the display is kinda small for us old farts...
    Press the "EQ" button, toggle to the GEQ (past the PEQ's) using the <Prev and Next> and the data entry wheel you select the frequency you want to affect, and then use the data wheel to cut or boost the frequency in real time. The RTA is usable in realtime as well.
  • recrec Posts: 44
    excellent
    thanks Gadget!
