First Edition DriveRack PA with QSC & Peavey GEar
I'm sure this has been asked 1000 times by now, so please accept my apologies in advance. I recently joined a new band where the previous singer was in control of the PA. From hearing the band prior to joining, I felt that there set up in the DriveRack may need to be tweaked. Here is the set up:
Peavey SP218 (2) Peavey SP2G (2) QSC RMX2450's 1 (bridged) for each sub cab, and 1 QSC RMX2450 (Bridged) for both top cabs.
Crossover point is set at 100hz with a low filter of 37.5 / db gain is at 9.0 for the subs and 6.0 for the tops. Just curious if this is a good set up for this combination of gear. They are running a 2x3 with a Mono sub output. I believe the subharmonics is engaged as well as the comp/limiter. Sorry, but I didn't get a chance to verify those particular settings. The system to me seems a tad weak on the low end. Again, I apologize for a repeated question here, just looking for some advise. Thanks for your time....................Eddie
Tell us a bit more about your setup, like do you have the measurement mic? why in the world are you using the sub synth? :?
Are you using the PEQ's what is set on the GEQ? I suppose you are compressing the whole mix? why?
Are you using the limiters?
So many unanswered questions...
Have you read the " READ ME FIRST BEFORE POSTING " section?
viewtopic.php?f=61&t=959
or seen the FAQ section?
viewforum.php?f=60
viewtopic.php?f=60&t=949
viewtopic.php?f=60&t=953
For some ideas on auto eq, It's the thing that's going to do the most to help you get what your looking for.
Ya, loose the compression on the mix, and there is no way to accurately set the limiter without the proper gain structure and then the limiter becomes a "just in case of calamity" backup... which is what it should be used for...
