Single amp w/tops and subs
I have a qsc gx5, and I would like to run two tops off of one side and two subs on the other channel.
I am running a 2x3 config (BFM speakers 2-OT12's and 2-T30 subs)
The subs are easy since I am running them mono and have only one cable coming from the DRPA+.
My question is how do I connect the tops since I have two outputs from the DRPA+ and only one half of the amp to connect to
viewtopic.php?f=60&t=2228
My Urei 1601s mixer has a mono/stero button on it.
Is that what you are refering to?
Peace
Would this be a feasible solution?
I get to actually play with the thing on Wednesday, but would prefer to not blow it up or something stupid like that. :-)
Why have two mono signals, separate them with the x-over, then not use one part of each?
Just come out of the Left out (mixer) to the Left in PRPX, then out Left hi and Left lo to your amp channels 1 & 2 accordingly.
I know that it's probably completely unnecessary due to the crossover, but I could also further "tweak" the sound with the main faders... if I want a touch more bass, for whatever reason, I could slide the left channel up.. or inversely, I could back it down, etc.
Please bear in mind that the farthest I've gotten with my DRPA is taking it out of the box and marveling at all the buttons on it... lol
My Urei 1601s mixer has a mono/stero button on it."
He said he had the same set-up. Just confusing when kick , bass, etc joined the conversation. It would not supprise me if a newbie DJ thought they could pull individual instruments from recorded material and route them to another output.
I'm actually a rather experienced DJ (17 years mobile, 5 years on air), but I'm also in a band, which is the primary reason I opted for the DRPA... I'm also 99% certain that I can't drive individual instruments from pre-recorded material through separate outputs.
So.. back to the matter at hand.. it doesn't matter. I'll test it both ways (single mono output from mixer and dual mono output from mixer) and use whatever I think sounds better. If the DRPA blows up, I'll send it back, get my money back and keep running my sound the way I have been for the last year, which, in all honesty, sounds fine for my purposes as is.
Thanks!
What you propose is a common trick to get "aux fed subs" when you don't have enough auxes. I f your not familiar with what aux fed subs are, check the FAQ section. You'll find that and a whole bunch of other info for driverack success.
So, put the DRPA on a table and push all the buttons and learn how to navigate the menus.
Also check out the "Start here" thread for gain structure and other setup tips.
I did split up the lows and fulls to left and right channel, respectively, and honestly, not only does it sound pretty good at the moment (I haven't gotten around to doing the gain setup yet, and it's still on the "flat" eq), but I'm really digging having the control over tops and bottoms.
The article on aux subs was perfect. I'd skipped that one because I don't have any livestock.. ;-)
