Macbook pro fusion windows 7 cannot connect
Ok well as best i can see my new macbook running windws 7 under fusion on the LAN cannot connect to a 641m. I have set up the IP on the zone pro to 192.168.0.50 on my old laptop via RS-232 i can see the zone pro in both windows and snow leapord via ip scanner with 20ms ping times yet the software does not see it any ideas on this would be great.
Have you tried setting your network card to "Bridged" instead of NAT, within VMWare fusion? Also, try turning off your wi-fi card to see if this helps.
