strange chirping sound even when muted
even when all outputs are muted, i get a stranged and intermittent chirp from the speakers. as though a gate is opening and closing. when i pull the input from the amp, chirping stops. When i pull the input from the Driverack, chirp continues. so i know its the driverack 260.
sometimes i also get as whiring sound from the driverack when i run the GUI.
ie start the GUI, whirring starts. close the GUI program and whirring stops.
I saved everything I could find on the driveware GUI.
How do reset the system?
The Soft Reset resets all operating parameters except user programs. The Hard Reset Procedure will reset all programmable
information back to the factory defaults.
All Power-Up Functions require a button(s) to be pressed and held as the unit power is turned on.
DriveRack 260 Power-Up Button Functions
Factory (“Hard�) Reset.
Press and hold the <STORE> button at power-up until the following message appears:
“! HARD RESET?�
“Yes <PREV PAGE>�
“No <PROGRAM>�
• Pressing the <PREV PAGE> button will start a Factory Reset (All User Programs will become
copies of the Factory Programs, all Utility settings will be defaulted, and all Security settings
will be defaulted).
• Pressing the <PROGRAM> button will abort the Factory Reset sequence and the unit will reset
normally.
System (“SOFT�) Reset
• Press and hold the <UTILITY> button at power-up until the following message appears:
“! SOFT RESET?�
“Yes <PREV PAGE>�
“No <PROGRAM>�
• Pressing the <PREV PAGE> button will start a System Reset (All Utility settings will be defaulted.)
• Pressing the <PROGRAM> button will abort the System Reset sequence and the unit will
reset normally.
Laptop?
Does it have a built-in mic?
Is it on?
Check the audio settings and mute the mic, if it is on.
