BASS Setting for PA+ and Crown MACRO 3600 to JBL 728S
Hello all,
I love this forum already. I'm having a tough time with my setup. To start off
I am not getting the right bass (true Bass). I still get voice frequency going out
of my bass speakers. Is there a specific frequency I should set the EQ or should
I reset my crossover setting.
Please Help !
Thanks in Advanced.
DJ Super Duke
Please Help !
Thanks in Advanced.
DJ Super Duke
Did you use the wizard, or a preset
do you have the mra
the more info the better
I looked up SRX 728 tunings and they are as follows with 725 tops...
31.5 BW18 HPF
80hz LR24 LPF
Bell PEQ @ 75hz Q=3.41 1.5dB gain.
Have you read the "Read me first befroe posting"?
viewtopic.php?f=61&t=959
and the FAQ's?
viewforum.php?f=60
Welcome,
Sounds like you have the x-over point too high (above 150hz maybe). Where do you have it set?
I appreciate your time helping me, much appreciate your time; I've also read the
Read me topic link.
Here is my full setup and maybe I can get a full configuration guide. Template for this set. Also
I play urban / Caribbean Club music , I need to also know the EQ graph type to choose when I plug
in my RTA Mic to set the auto EQ.
Here is my set:
High: Amp: Crown Xti 4000 to Speakers: JBL SRX 4733X
Low: Amp: Crown Macro 3600 to Speakers: JBL SRX 728s
Again Thanks!
I guess this is way too high. I also just lowered my db to0.
Do you happend to know why in the crossover menu the is
High: 150 hz bw 24 0 db
low: 22.5 Hz bw24 db then 150 Hz Bw 24 Do you know what this last set of
setting means/control?
I am not doing bi-amp at all. Those numbers are already set on my crossover. I was wondering
why on the Low side of the configuration low: 22.5 Hz bw24 db then 150 Hz Bw 24
there are 2 different setting for Hz as oppose to the Highs only has one setting.
DJ Super Duke
The ones I gave were for as I said...the SRX 700 series, JBL doesn't usually provide cross platform tunings... that is to say, Sr and SRX series, but in this case they provide info for the SR4733 and SRX728.. they suggest selecting the SR4733X with passive subs.. THEN they provide the info that I suggested previously. It's all available in the "downloads" under "tunings" @ JBL professional ...
Those are the actual numbers they provide, and they specify software version 1.0 which is the oldest driverack version...the newer one has SRX tunings, the older SR tunings...So plan on entering the info manually using the numbers I provided...
with my fresh cup of coffee.
so in a nut shell for my system not running bi-amp and with the RTA mic what should my configuration should be
for :
Also does the Crossover setting stay static for all Presets? or does each preset keeps their own xover config?
Last question : Does the usb jack just for firmware upgrade , cause it seem like the Drive Gui only works for the
higher models of the DRPA not the DRPA+.
Duke
Dennis
inputs for both highs and lows? Correct?
These will be your crossover settings, and the one PEQ JBL suggests for the subs.. this doesn't mean that the speakers will be FLAT.. for that you will need to have the measurement mic and follow the auto eq info in the FAQ section and the "Start here" thread for setup and gain structure...
Only the ones you set up and SAVE if you don't press the [store]button 3 times (and answer the questions) (where do you want to store the preset? are you sure you want to replace this preset... name the preset...) you will not have this stored for future retrieval
That is ONLY for future update of presets (pre loaded speakers and amps)
No, you want to use the FULLRANGE inputs of all the speakers...
THANK YOU, THANK YOU, THANK YOU
MERCI, MERCI, MERCI
I guess this will be enough for now as I can only test it when I set up for my gig on Friday.
I will figure the additional stuff Later. Like FeedBack and compressor Limiter, I will also use the
recommendation for the Gain Structure.
Thanks again.
DJ Super Duke
your welcome..
