CD Horn Equalization
In reading the posted info on CD Equalization, is this something that the drive rack pa+ can do and if so would it be set automatically using the RTA Mic or is it something that must be configured by the user?
viewtopic.php?f=60&t=1080
as for the CD horn EQ...
http://www.peavey.com/support/technotes ... orn_eq.cfm
and essentially what the article says is... set a set a 6 db/octave hi shelf starting @ about 3-4khz...
More questions?
That's a bad idea... NL4's are typically wired ...
1+1- lows
2+2- hi's
So,
Biamp the tops using the above,
and use 1+1- for the subs...build a jack panel if you have to that way you can't use the wrong wire for the wrong speaker...
For any further clarification we need much more info..
I am working on a jack panel now, I should have all of my cables and connectors by Friday. The 1+1- and 2+2- was how i was going to biamp the sp2 tops, but for the sp218 bottoms, they are dual 18 inch bass speakers. Here is a pic of the rear speaker panel of the sp218's.
Dennis
Well.. that all depends on the power available... you would NOT have the same output if you have a pair of 8 ohm woofers on a 3000 watt Behringer EPX amp (4 ohms 1500 watts per driver) and 8 ohm stereo (500 watts per speaker...) that's a pretty big improvement...
If you have the NL4 cables that are wired properly...(4 conductors...VERY expensive) there is no problem because they are wired properly...
I am using 4 strand 10awg for my sub and it is powered by a peavey cs4080 (1250 watts per channle at 8ohms). I have the amp running in parallel with both speakers wired directly via the NL4 at the speaker end (all 4 wires). On the amp end 2 wires are the 1+1- and wired to one NL4 and going to channel B and the other 2 wires 2+2- going to the amp channel A.
Dennis
Would the amp see a 4ohm load or 8?
Dennis
Dennis
If connecting to the same amp with the same input (sub) signal.
Dennis
When I try and do a separate configuration just for the bi-amped speakers without the sub, I cannot get the drive rack to utilize the mid amp for the mids of the bi-amped cabinet. What am I doing wrong? I don't want to use the amp that I am using for the lows to run the mids in the bi-amped cabinet. Is there a config that I can use that will recognize the bi-amped speaker configuration?
I have found that I can use the 2x5 and just turn off the third amp that runs the bass, but not sure if this is the correct thing to do. Please advise.
thanks Dennis
