482 relays "chattering", fan noise..or is it possessed?
Often, when I powerup my DR482 it powers up fine, but then it sounds like relays near the on the back of the unit are all chattering?! It could be the fan even? I cant really explain it easily, but lasts for around 10secs after around 5-10 secs after powerup. I did a hard reset which seemed to fix it the few times I powered down and up, however when I reloaded my usual file the fault seemed to return.
I havent yet replaced the 'bios' battery inside but will do to see if that helps. Also when I had it plugged in thru the mixer and amps it didnt seem to play up.
http://www.dbxpro.com/faqs/index.php?q= ... earch&cat=
Hope this helps.
