Driverack crossover setting
Hello forum,
Just curious on some ideas for crossover and other settings for my PA using the Driverack PA, as the speakers and amps I have are not listed in the Wizard. Here's what I'm running for my 7 piece GB/club band:
Mains: pair JBL MRX 515s powered by QSC PLX 3402 stereo
Subs: pair JBL JRX 118s powered by QSC GX5 stereo
Also any eq and other tips are greatly appreciated.
Oh, and sometimes for smaller gigs I leave the subs at home and have a separate program on the driverack for it.
Thanks so much for everyone's help and input.
Mike
Mike
Start here thread:
viewtopic.php?f=61&t=959
and the FAQ section:
viewforum.php?f=60
This is so that you might learn something as you get the info you want. You'll find that there is a thread for just about anything...
viewtopic.php?f=60&t=1196
for if your speakers and or amps are not in the presets
viewtopic.php?f=60&t=1204
What crossover slope and type to choose
viewtopic.php?f=60&t=2346
Auto Eq.. the basics..
You'll find that amp power and the speakers natural 3db down point are good starting points to consider. The GX5 is not bridgeable from what I understand, so you have only stereo as you are doing. Therefore a 2x3 (use the parallel feature on the GX5) or 2x4 is possible. Unfortunately those aren't subs but more like lo mids.. and @55 hz they are 3 db down...so I'd set a BW18@ 55hz.. HPF...Why did you get subs that don't even go as low as the tops can? I mean the MX515's are 3db down @ 52 hz...makes no sense to me... but...The LPF isn't as big an issue as you have decent power in bridged mono, but your short in stereo (700 watts on a speaker that can handle up to 1600 watts peak..that's the headroom you really should have to keep from blowing drivers) so in stereo I'd set a 100-118hz LR24 filter for the cross from the subs to the tops...that will minimize the LF in the tops so they are clearer in the low mids...
As for eq.. I don't have any of those speakers.. but as I indicated the auto eq can help.. you need the measurement mic though...
