please help me get rid of feedback
can someone help me get rid of these feedback im having my set up is
2 jbl srx738
qsc rmx 4050
lexucon mic pre amp
dbx 234 xover
dbx 166xl compressor
mic shure beta 87a
connection: jbl srx738>>qsc4050>>dbx 166xl compressor>>dbx 234 xover>>lexucon mic pre amp>>shure beta87a
this set up is for a home karaoke i dont know what im doin wrong either im connection wrong or something everytime i turn up the music and try to sing then i get this crazy feedback and im scared if this keep happenin i might blow up something the compressor i adjust all knob set at 12 o clock and the qsc 4050 i turn the knob only to 30db sorry im just a noob i was just told to set up like this and everything should be perfect i feel the power when i just play cd music but when i start to sing karaoke it just dont work i get this loud feedback and it scared the shit out of me can someone please help me thanks i really appreciated
2 jbl srx738
qsc rmx 4050
lexucon mic pre amp
dbx 234 xover
mic shure beta 87a
compressor...take it out of the system and try it. This is troubling to me:
dbx shows the knobs all at 12 o'clock, but the actual settings when properly set will look NOTHING like that... why are you
compressing your voice anyway? are you an inexperienced singer? With dynamics that are all over the place you are trying
to control? Compression can cause feedback as the compressor hunts for sound if set up improperly.. also, with only a set
of SRX738 why do you need a crossover? are you bi-amping them?
Look, JBL is known for being harsh and high endy...add to that a compressor set to a 2:1 ratio (12 o'clock) with the
threshold set @-10 (12 o'clock) (and god knows what the button positions are) is a recipe for some piercing feedback...
Before you put the compressor back in to the system you need to read up on compressors.. type in "Compression" in a
Google search and follow the links... read the dbx paper, "Compression 101"
ftp://ftp.dbxpro.com/pub/PDFs/WhitePape ... %20101.pdf
I suspect you'll have more questions.. if so please include ALL equipment in the chain.
I understand your English may be weak.. don't give it another thought..
sorry...
Where are you exactly? for a few bucks more than the Beta 87a you could get a driverack PX and have the ability to tune, and equalize your setup, and help protect your speakers...you 223 won't do that...
No the AFS224 won't do the job by itself... the PX has that built in BTW.. If you want to use that mic you will need a system that is well tuned and flat AND you'd need some skill to boot (mic technique wise...) Sorry dude you got sold a bill of goods in a way.. No you probably don't need the Compressor... Why not sell BOTH the analog crossover and AFS224 and get the PX in their place... you could maybe return them to the GC and tell them your REALLY REALLY upset about this, and get the PX.. then you might be able to use the mic... otherwise, get a different.. DYNAMIC mic...the condenser is just too sensitive for the setup the way it is...
:arrow:
Ok, we have determined that the problem here is an overly sensitive microphone on a system/speaker set that is peakey and overly bright.. a bad combination... but NOT one that cannot be fixed...
The recommendation of the DRPX would replace the compressor and the 224 crossover and offer the tools needed to set up this system to be able to use the "overly sensitive" Shure Beta 87a condenser mic...
I guess I'm not certain what you mean by : :?:
I thought I had?
If your looking for specifics, you need to have the PX in hand and be able to use it with your system... and the setup info we have provided for you here in the "start here" thread and the "FAQ section".
Otherwise you need to go with a different mic...one that is NOT a condenser...a dynamic like the Audix OM7 or maybe the Heil PR35 or some other great sounding dynamic mic (not the SM58.. a great mic for years but not the highest fidelity mic around, but one that is great at rejecting feedback...)
More info needed.please be specific what you are asking...
The PX isn't very difficult to set up, we can help with that. It's pretty much got a wizard that helps set it up, but you can define the setup to fine tune the setup. The Auto Eq is not foolproof, but again , we can help you through it.
