Auto-EQ without RTA Mic?
I am a newbie but have looked around and haven't found this question answered on this site or in the manuals. We were given a PX but not the RTA mic. Is it pointless to do the auto-EQ with another mic? We have several Sennheiser e835s, and when we were messing around with the setup we used this for the auto-EQ.
We'll be using the system in a small bar for live bands. None of us have much sound tech backgrounds, so the auto-EQ route is much more attractive then manually customizing the settings. To be honest, I can't remember the exact models of the speakers and sub we use, but they were listed in the PX.
The answer is ..... NO.
Using the auto-EQ in an establishment is not going to yield good (reliable) results anyway.
What is your set-up?
Set up a 2X3 (for mono subs) or A 2x4 for stereo subs
xover setup:
Sub:
HPF 30hz BW18 (assuming a powered sub)
HPF 90hz LR24
tops
HPF 90hz LR24
That will get you started... then we'll talk...
Also, I forgot to ask about the auto-level. Did my use of a non-RTA mic render the auto-level useless as well?
And finally, I misspoke on the model of the QSC. We have two HPR122i, not 152is. Let me know if that changes the crossover settings you recommended.
1. I like to do a custom setup in the wizard...
2. I usually skip the auto balance step because I use mono left 1X2 tops and subs out of the left outs, and a mono monitor send form the right input and right mid output... this means I need a dual mono system so that the auto EQ will need 2 passes... One for the left channel (always first) and two for the right channel and a monitor mix.
3. In your case, yes skip the auto level it too is null and void with the wrong mic...
4. I do like a new wizard preset even if I don't get an auto eq run...even if I just set up the crossover and rough in the gains (and I do it with my ears... not the auto level feature...YMMV..
5. yes, I would raise the crossover point to at least 100 hz LR24, possibly 118hz and see how it sounds. The reason is the midrange vocal sound...with a higher hipass frequency the midrange should be smoother.
I got the part about you being a newbie..what I mean is, as in the gain structure setup thread here:
viewtopic.php?f=61&t=959
I like to rough in my amps and speakers .. say that the sub amp and mid amp are the same watts wise, but the mids are 99 db efficient and the subs lets say 94dB..that's a 5 dB difference I usually make up in the xover gain.. BUT I usually tell novices that it's easier to (in in the long run makes no difference one way or the other) to just use the gain controls on the amps/speakers themselves. It's just easier.
