PA+ Driverack or Crossover Question???
rgalv001rgalv001 Posts: 1
edited July 2010 in PA General Discussion
I have 2 EV Eliminator speakers and 2 Yamaha 18" subs for my system. These will be powered with 2 QSC pwr amps. Will the Driverack PA+ eliminate the use of a crossover? The guy at the music store recommended a crossover instead of a Driverack PA+. I thought the driverack eliminated the use of a crossover. Help!
  • DraDra Posts: 3,777
    Yes it does.
    Go to the READ ME FIRST section. Lots of good info there for beginners. Tips and tricks, how-to's, etc
    Go to the main DBX - Driverack site and read the cut-sheet. It lists everything the DRPA+ can do.
    OH! And read the manual also. We're always here to answer questions you may have.
  • rgalv001rgalv001 Posts: 1
    Thanks! Why would he not want to sell me the DRPA+??? Is it because I'm running the EV's full range and subs (2-way system)?
    I'll read on...
  • GadgetGadget Posts: 4,915
    Sounds like a real winner.. not only is the Driverack a crossover.. it is FAR superior to most any analog crossover, and has alignment, delay, and dynamics as well eq as EQ...a real full toolbox to help with your sound..
    Some people have a bias against digital or technology in general. Maybe he is intimidated by the Driverack. The analog x-over is simpler, but not nearly as good. In the same way, a peanut butter & jelly sandwich is easier to fix than a ribeye and baked potato with the works.
    I choose steak.
