Newbie who needs assistance
We are installing a new DRPA+ in our church. I have some old Yamaha S4115 15" with horn for mains and seperate 18" subs. The mains are powered by a QSC GX5. The subs are powered by a QSC PLX3402 bridged. All of the components in the old cabinets are new. The specs are below. I have read the manual and many posts on the forum. Honestly, the more I read, the more confused I get. I need assistance with the initial setup/config based on my hardware. Thanks for the help.
Xover - Eminence PX2-1K6 in main cabinet
SPECIFICATIONS
Type 2-Way
Cabinet Ready Yes
Crossover Frequency 1.6kHz
Slope – Low Frequency 12dB/octave Butterworth
Slope – High Frequency 18dB/octave Butterworth
Impedance 8 ohms
Power Handling 400 Watts RMS
High Frequency Level +/- 9dB
Type 2-Way
Cabinet Ready Yes
Impedance 8 ohms
HF Driver - Radian 475PB – 8ohm in main cabinet
Specifications
Throat Diameter 1" / 25mm
Impedance 8 or 16 ohms
D.C. Resistance 6.2 or 12.4 ohms
RMS Power Rating 40 Watts above 1.0kHz
Program Power 80 Watts above 1.0kHz
Sensitivity (1W/1m) 111dB SPL
Frequency Response 800Hz - 20kHz
Recommended Crossover 800Hz @ 24dB or 1.2kHz @ 12dB
Voice Coil Diameter 1.75" / 44.45mm
Magnetic Assembly Weight 38.4oz. / 1.09 kg.
Flux Density 1.88T
Mounting Information
Overall Diameter 5.25" / 133.35mm
Overall Depth 2.6" / 66.04mm less studs
Mounting (2) 1/4-20 studs on 3" dia. centers
Net Weight 6.4 lb. / 2.9 kg.
Materials
Diaphragm Heat-Treated Aluminum Alloy
Voice Coil Edgewound Copper Clad Aluminum
Diaphragm Suspension Mylar
Input Connectors Goldplated Push-Button Terminals
Magnet Ferrite V
SPL vs. Frequency
Mids - Eminence KappaPro 15-A in main cabinet
SPECIFICATIONS
Nominal Basket Diameter 15" / 381mm
Impedance 8 ohms
RMS Power Rating 400 Watts
Program Power Handling 800 Watts
Frequency Response 54Hz - 4.2kHz
Sensitivity (1W/1m) 101.6dB
Voice Coil Diameter 2.5" / 63.1mm
Rec. Enclosure Vol. (Sealed) 28-42.5 Liters / 1-1.5 cu. ft.
Rec. Enclosure Vol. (Vented) 57-133 Liters / 2-4.7 cu. ft.
MOUNTING INFORMATION
Overall Diameter 15.32" / 389mm
Bolt Circle Diameter 14.562" / 369.9mm
Baffle Cutout Diameter 14" / 355.5mm
No. Of Mounting Holes 8
Mounting Hole Diameter 0.275" / 7mm
Overall Depth 6.06" / 154mm
Magnet Weight 80 oz.
Shipping Weight 19.1 lbs. / 8.7kg.
THIELE-SMALL PARAMETERS
Resonant Frequency (fs) 42 Hz
Impedance (Re) 5.71 ohms
Coil Inductance (Le) 0.83mH
Electromagnetic Q (Qes) .44
Mechanical Q (Qms) 4.73
Total Q (Qts) .40
Compliance Equivalent Vol. (Vas) 243.5 Liters/8.6cu. ft.
Voice Coil Overhang (Xmax) 3.2mm
BL Factor (BL) 14.5 T-M
Surface area of Cone (Sd) .08563m2
Lows - RCF L18P300 80HM in separate sub cabinet
SPECIFICATIONS
Nominal Basket Diameter 18"
Impedance 8 ohms
AES Power Rating 1,000 Watt
Program Power 2,000 Watts
Frequency Response 35Hz - 1.0kHz
Sensitivity (1W/1m) 97dB
Voice Coil Diameter 3.94" / 100mm
Max. Excursion Before Damage 1.6" / 40mm
Max. Crossover Frequency 150Hz
Voice Coil Winding Depth .9" / 23mm
Number Of Layers 2
CABINET SPECIFICATIONS
Enclosure Volume 200Liters/7.06cu. ft.
Tuning Frequency 33Hz
Vent Diameter 200mm/7.9"
Vent Depth 280mm/11.03"
MATERIALS
Cone Material Paper Pulp
Voice Coil Material Copper
Diaphragm Material Paper Pulp
Surround Material Polycotton
Overall Diameter 18.5" / 470mm
Bolt Circle Diameter 17.24" / 438mm
Baffle Cutout Diameter 16.4" / 417mm
Mounting Hole Diameter 0.315" / 8mm
Flange Thickness .6" / 15mm
Overall Depth 8.3" / 209mm
Volume Displaced By Driver 6.5 Liters / .2ft^3
Net Weight 14 kg. / 30.8 lbs.
Shipping Weight 14.8 kg. / 32.6 lbs.
Resonant Frequency (fs) 33 Hz
Impedance (Re) 5.0 ohms
Coil Inductance (Le) 1.9mH
Electromagnetic Q (Qes) .34
Mechanical Q (Qms) 8.3
Total Q (Qts) .33
BL Factor 23.5T-M
Compliance Equivalent Vol. (Vas) 226 Liters/7.98cu. ft.
Voice Coil Overhang (Xmax) 7.8mm
Reference Efficiency 2.3%
SPECIFICATIONS
Type 2-Way
Cabinet Ready Yes
Impedance 8 ohms
Type 2-Way
Cabinet Ready Yes
Impedance 8 ohms
Specifications
Flux Density 1.88T
Materials
Magnet Ferrite V
SPL vs. Frequency
SPECIFICATIONS
Impedance 8 ohms
Total Q (Qts) .40
SPECIFICATIONS
Impedance 8 ohms
Number Of Layers 2
MATERIALS
Total Q (Qts) .33
BL Factor 23.5T-M
How many is "some"?
Also, How many subs is "separate"? What type cabinet? (DIY, copy of a commercial design, etc.) what is the 3dB down point of the cabinet?
See, we need those things to evaluate your setup and make recommendations...
This:
FYI, an example of useful info:
SPECIFICATIONS:
Type 2-Way
Impedance 8 ohms
The MISSING info here is horn pattern: insert pattern info here________________ (like 90X40, 60X40..etc so we can determine coverage angles))
Flyware if it's hung...So we can verify it's safe to fly...
and some of the driver info is also pertinent..
efficiency of the components,
voice coil diameters,
Make and model of drivers is also nice...
The rest is all pretty much superfluous...That's just FYI because it makes it kind of difficult to find the info we do need to make the recommendations.. I know you didn't know this (most likely) and realistically all we REALLY need is coverage pattern, 3db down point (frequency response), power handling of the overall speaker cabinet, and power available for the cabinet.
The 3db down point is the point at which the frequency response drops below it's published "average" frequency response.. there is also a typical 10 dB down point... but it's mostly useless to me...3dB is a relative doubling/halving of SPL levels and is considered the smallest noticeable changes to the human ear. 6dB is a doubling of amplifier voltage.
The horn pattern is important and is typical to the horn # I would assume 90X40 for a typical Yamaha horn with a 1" exit.. it is pretty certain that the driver is NOT the original...as for the woofer... Eminence was the most likely original provider, but I cannot verify if that is the original woofer... and that is important because the cabinet is designed around the woofer.. not the other way around...
You have also not answered the question of how many of each speaker...
Yes, but the cabinet is of interest here.. especially in the sub, because we have nothing to go on for what box the woofers are in...
All too often people just throw any old speaker in a box that was designed for a different speaker...and in this case the driver is most likely NOT original, and as such you could have major issues to deal with in the tunings... you may NOT be able to right the mess.. even with the driverack without bi-amping the tops... and that would be a JOB...
The good news is that the DRPA+ has a great tool set, and should be able to get you a good sounding product...
Again... more PERTINENT info would be necessary for the best recommendations here..
The cabinet dimensions for both the mains and the subs are 24.5�w x 30�h x 17.75�d.
The distance between the cabinets is 32‘.
The room size is 40’w x 64’d x 16’h.
Main Cabinets
There are 2 ports/cutouts on each main cabinet.
The diameter of the ports on the main cabinets is 3.75h� x 1.75�w.
The ports are open inside the cabinet.
The 3db down point for the mains is 65hz according to the supplier of the components.
The mains were fitted with the following:
Xover : Eminence PX2-1K6
HF Driver : Radian 475PB – 8ohm
15� Mids : Eminence KappaPro 15-A
I don’t know the horn pattern. Hopefully you can tell by the picture.
The mains are powered by:
QSC GX5 Power Amp Used for Mains
Output Power, 1 kHz, 0.1 % clipping
8Ω, both channels driven 500 W
Sub Cabinets
There are 2 ports on each sub cabinet.
The port diameter on the sub cabinets is 6�.
The port depth on the sub cabinets is 10�,
The 3db down point for the subs is 45.7hz according to the supplier of the components.
The sub cabinets were fitted with the following:
18� Lows : RCF L18P300 8 OHM
The SUBS are powered by:
QSC PLX3402 Power Amp
20 Hz–20 kHz @ 0.03% THD
8Ω per channel 700W
20 Hz–20 kHz @ 0.05% THD
4Ω per channel 1100W
EIA: 1 kHz @ 1% THD
8Ω per channel 800W
4Ω per channel 1250W
2Ω per channel 1700W
Bridge Mono:
16Ω, 20 Hz–20 kHz, 0.1% THD 1400W
8Ω, 20 Hz–20 kHz, 0.1% THD 2200W
4Ω, 1 kHz, 1% THD 3400W
Currently the subs are wired for L/R coming out of the DRPA+ and into the PLX3402. The PLX3402 is bridged mono to the two subs that are linked together. I think this setup provides 3400wpc @ 4ohms for the two 8ohm subs which would be driven at 4ohms total. Please advise if I should change this setup.
Please keep in mind that I am an idiot, so please reply in layman terms. Thanks for the help and let me know if you need any other information.
Your sub amp is 3400 watts "bridged" at 4ohms.
(2) 8 ohm cabs together = 4 ohms.
You would have 1700 watts per cab.
Do you still have the old crossovers that may have model numbers for the cabs? Year of these Yamaha's?
These guys need every detail before they can give a starting point.
It's the REALLY busy season...
Those subs... if properly tuned (which I doubt since it looks like a clone of some old JBL cabs that someone just added a "Better" driver to an old design) that driver can handle 4000 watt peaks..
So with a 47.5hz 3dBdown point you could safely go to 40 hz BW18 with those subs. With 1700 watts it might be smart to go to with 45hz BW18 though..
I'd set the LPF @ 100 hz LR 24 and the HPF for the tops @ 100hz LR24 to start with. Some fine tuning after that you might find that a few hz up or down might yield a better sound.
This makes no sense to me because L/R assumes stereo outs and Bridged mono is ... well mono...
A 2X3 would be fine for a fullrange top and mono subs...
Looks like a typical 90x40 horn...which is OK for 1 per side, but will usually spray sound on the side walls with this pattern and make reflections a problem. A tighter pattern and flown mid highs would better cover the congregation... and keep the sound on them and off the reflective surfaces... but that wasn't the question...
