How I can configure DriverRackPA+ with 2 speakers only ?
Dear Friends,
I bought one DriverRack PA+ and I can not found in the manuals how I can set this device to work only with one apmplifier JBL MPX600 and two passive speakers JBL MR835 without subwoofer, in the manuals I only found examples to work with 2 amplifiers and with at least one subwoofer.
I´d like to know what I have to do to complete the configuration of the DriverRack PA+ to work with this amplifier (one) and this speakers (two).
Thank you very much.
Ok 8)
Think of the driverack as a group of filters that can be limited.. or fullrange..or anything in between. Your can use either channel independently for you particular setup. Simply use the left input and the left hi output. Then set the HPF @ the 3dB down point of your speakers on the left hi outputs bandpass filter/crossover...
You could use a custom setup or the stereo fullrange one just don't use the other side of the driverack.
Thank you very much for your help.
I will try to do the activation of the stereo fullrange today.
Regards.
Everything works perfect !!!
Right now the DBX Driver PA+ is working very well.
Regards.
Oscar
Have you seen the system setup or FAQ section here?:
viewtopic.php?f=61&t=959
viewforum.php?f=60
Lots of tips and tricks there...
