Gain control in xover section
In the xover section of the drpa there is a gain adjustment should that be set at zero? can setting that to high cause problems? It makes a considerable difference in volume to turn it up but then when you do you lose lots of control from the faders on the mixer only being able to push up the faders a little bit, just wondering if there is a common place those gains are set, thx
Dennis
Does your mixer have any switches or knobs on the back near the output connectors?
