Problem with one speaker
premier1
I had asked this before but didnt really get an answer, the only speaker that clips on me is the top right and only on the amp. I do not know why, I thought maybe the tweeter was blown ( dont know how to tell) but it sounds great at a bit lower volume, I can hear the highs etc no problem, could it still be there is something wrong with the speaker itself? or could there be another explanation I can look into or is it just a matter of turning down the volume knob on that side ?. Thanks
That is a confusing statement. Can you clarify?
Here is where basic trouble shooting comes into play
The variables
1 The amp
2. The speaker cable
3. The speaker
4. The input signal to the amp
The first rule of troubleshooting is "divide and conquer" In other words... the signal chain is like this
Driverack>cable>amp>cable>speaker
(this means start in the center and see if everything is good to that [point)
the easiest things to check here are the cables.. so one at a time (speaker cable first because it's the most likely to cause a problem) swap the cables from a known good channel to the bad channel...If that fixed the problem you need to fix, or replace the speaker cable.. if it didn't fix the problem swap out the other cable...
If that didn't fix the problem then try changing the known good speaker to the bad amp channel
If that didn't fix the problem switch the bad amp channel to the other driverack channel...
If that didn't fix the problem it's the amp OR the settings on the back of the amp are different.. as in the limiter is engaged on one channel...
and as Dra said the difference between 12 and 14 gauge on short runs is minimal... there must be a problem with that wire...
g
