Settings for SP2 and SP218's on Driverack PA+
Hello
I have the newer style SP2's and SP218's from Peavey and the setting are not in the Driverack PA+
Does anyone have an idea for the settings for these? We are running in Stereo mode
George
George
SP2 - http://www.peavey.com/assets/literature ... 0_9080.pdf
SP218 - http://www.peavey.com/assets/literature ... 6570_5.pdf
Thanks George
We are using an EP4000 to run the tops and an EP4000 to run the Subs all in Stereo
George
The reason I bring this up is...you are pretty underpowered. Those speakers are pretty power hungry.
Power handling: 2400 watts program, 4800 watts peak
The amps will give:
4000 watts (PEAK) power into 4 ohms or (by the manual) 950 watts @ 4 ohms stereo (SP218)...and 550 watts @ 8 ohms (SP2)
For the SP218's that's only about 500 watts per driver...
Set the HPF @ 45hz BW18
set the LPF @ 100hz LR24
For the tops set the HPF @ 100 hz LR24
These points takes into consideration the power available.. you should probably have one amp in bridged mode per sub and top... but you could run mono on the tops to get more power for them...then you could lower the HPF.
Is that what you would recommend?
George
Then you could lower the HPF/LPF to 90hz, have better low end, and actually have some headroom in your system... much less likely to hurt the speakers...
George
I cant seem to get the settings right my subs have no oomph and my tops arent as clear as I know they can be.
Here is what I have for Gear
Driverack PA+
DBX266XL
TC Electronics M-ONE
Behringer Ultragraph Pro FBQ3102
4 Behringer EP4000 Amps
4 Peavey SP2's
4 Peavey SP218 Subs
Havent hooked all 4 tops and subs up yet as I know I dont have enough power to do so at this time.
I know I should have bitten the bullet and splurged on better amps but is there a way to use this system to it fullest potential the way it is for a few months until I can upgrade the power?
Any help would be appreciated as far as settings etc I am technologically challenged when it comes to the Driverack terminology etc
George
Dennis
I have a couple modified SP2's and 2, with a dedicated BEH EP2500/QSC RMX 2450/Nady SPA2400 (all made in the same factory and essentially the same amp) and bridged mono ( 2 cabs paralleled ) they simply kick ASS! they Get extremely loud and dynamic...
As for the subs, you will need to put one amp on a single bridged 4000 (which... unfortunately is the exact same amp as one listed above but they decided to use the PEAK output instead of the more reasonable average output with the rated distortion figures) This will give you decent power... but those subs need a LOT to get going.. and as you know they are rated @ 2400 watts program and 4800 watts peak...so a single EP4000 will actually give you 400 watts PEAK power and about 2500 watts average...watch for the clip lights a see the below for setup.
so thats an EP4000 for EACH speaker in bridged mode...and yes, as Dennis pointed out the bi-amping the tops will make a big difference, but then you are already handcuffed by the power to the subs so I'd address that first...
So Set the HPF for the subs @ 45hz BW18
Set the LPF for the subs @ 100hz LR24
Set the HPF for the tops @ 100hz LR24
List all freqs with ...
Cut:
More than 9db -
5-8db -
Boost:
More than 9db -
5-8db -
Using compression or limiting?
George
