Drive Rack PA crown xs1200
mitchiemashamitchiemasha Posts: 26
edited November 2010 in PA General Discussion
It's been a while since I've asked for help but i'm back...
When using the wizard on the drive rack pa I noticed there is no Crown xs1200. Yet the othe xs models are there. Which amp setting would you recommend?
I did do a quick search but no luck.
Previously I hadn't been using the wizard and jst ammending presets to what I required.
Thank you.
  • GadgetGadget Posts: 4,915
    If you REALLY must know, go to the Crown site, look up the 1200 find the spec for "Input sensitivity" ...in the spec sheet... then find another Crown amp (that IS in the driverack) and has the same sensitivity...
    OR use the gain structure and let that set the sensitivity...
    viewtopic.php?f=60&t=1340
  • yeah! I had been doing it manualy, I was just curious to why it wasn't there.
    I'll jst stick to that method, thanks.
    FYI the XS series of amps are discontinued.. that's probably why they are not in the driverack. I did find a document that indicated that the sensitivity is 1.4 volts... the same as the XTi series.
  • Mine has the Xs range in just not the 1200, i'm guesing that was released after my drive rack pa was made.
