Is My DriveRack PA+ A Fluke?
Thanks Gadget for answering my first question about the DRPA+.
Yesterday, I inserted it into my PA rack. When I turned it on, my Senheiser wireless mic receiver went into an awful feedback fit. I quickly turned the DRPA+ off and the problem was gone. I've tried moving the DRPA+ above AND below the Senheiser rackspace with no luck!!! BTW, the reciever only acts up when the DRPA+ is fully inserted into the PA rack.
I've also "tried" to do some web searches this morning about a related issue but have turned up a blank. The DRPA+ is brand new and appears to be working fine. Is there some fluke issue that I've missed?
I've tried MANY different frequencies with no avail.
There's also no hot chassis issue either. (checked that)
PLEASE tell me something else! I guess I'll have to call, (sigh) customer no-support.
Dennis, the hot-chassis was checked with a Volt-meter. Keep in mind that my other rackunits have behaved perfect for the last few years. The problem has only began when the dbx is powered on.
Strange as it may seem, last night I transfered the Senheisers to the VERY top of the rack and put the dbx at the VERY bottom. As of right now there is no interference.
It hasn't made me feel too much better because the original interference didn't happen immediately. And no I didn't push any buttons that made it start.
Are you thinking that the dbx is not grounding properly? BTW, I have a recording session for the next two days but I'll try to check back.
If the DRPA+ was giving off some RF interference you would have that interference when the DRPA+ was anywhere near the Sennheiser...not just when fully inserted...seems like when the chassis touches the rack, that is when the fun begins...
That's the reason I was thinking that even though you didn't measure a difference of potential, there might be a very slight (read this non measurable with anything other than a micro-amp meter/voltmeter or oscilloscope) difference in the two chassis...the "Isolation" I speak of is "rack ear isolation washers" that keep the chassis of a suspected device from interacting with other devices in the rack. Some equipment, like the Crown Macrotech amps, use a grounded bridge setup... these things can cause interaction in some instances. Could be a leaky cap in any of the devices in the amp rack, it doesn't necessarily mean the DRPA+ is the culprit, just the device that is the impetus...
