Low End Hum on Stage
Hello
We have been experiencing a bad low end hum on the stage only and was wondering if anyone else has had this issue or may have a suggestion on how to fix it.
Our system is in stereo mode and we are using the following equipment
1 - Behringer EP4000 for the tops 2 Peavey SP2's newer version
1 - Behringer EP4000 for the Subs 2 Peavey SP218's newer version
1 - Driverack PA+
1 - DBX266Xl Compressor
1 - Behringer FBQ6200
1 - Behringer XR4400 Gate
1 - TC Electronics M-One XL
The Subs are crossed over around 120HZ and the highs are at 90HZ. I have never used the EQ settings on the Driverack or used the filters etc
George
1 - Driverack PA+
George
Dennis
Do you mean from the monitors , or that you only hear the hum on the stage?
Sorry Dennis what do you mean by input list? I am not real experienced with the Driverack
You have left out a WHOLE lot of info here...
1. Are you using monitors?
2. IF there are monitors does the buzz go away with the monitors off? FOH off?
3. is it any one mic or all mics?
4. How are the monitors routed (as in aux sent?)
5. what is the entire setup.. how many mics, any phantom powered ones (are you sure any and all phantom power is disabled if not)
6. are there any direct boxes, or instruments connected directly to the mixer...
7. exactly how are the equipment pieces hooked up? be specific...
8. is the whole system hooked up to the same power feed... mixer, amps, and instruments that are directly connected to the mixer on the same power...(GROUND LOOP)
Too many possibilities...
Where are you? Are you the sound man out front, and when they (on stage) say there is a hum, you tell them that you can't hear it?
