How to Auto EQ with sub?
I've used the auto eq function before to adjust the frequency response of individual speakers. Is it possible to do this effectively when using a sub? I've been using the boundary method with the reference mic close to the floor and the speaker aimed at that point.
Any tips?
Any tips?
A null at the x-over point, could mean a phasing issue (time / distance), a polarity issue, etc. To fix some of these problems, perhaps separating the filters, moving either the sub or top / adjusting the delay, etc.
So, Yes. Together is best. But individually will also tell you alot about each's charactoristics. Although for the subs, you won't be able to "finish", but the important data will still show up on the GEQ.
For a baseline though (for subs), outdoors is the only way.
Thanks for the comments...
