Px right for me
Scumbag
Hello everyone!!
Well I would like to ask a question.
I am a 2-3 times a month muscian and sound guy, and would like to know if the PX model is what I need?
I am using Yorkville NX55p's for my tops and LS720p's for my subs. These are all Yorkville powered speakers. I looked it up on line and I see that my speakers are listed in the PX Wizzard setup. . I also have an A&H Mixwiz board.
I mix all the bands sound from stage because I am one of the players. We play mostly 50's'60's-70's-80's music with room sizes diffrent from week to week. We are a small setup with Bass, Drum Machine, Keys, Guitar. I also am using aux controled subs, but if the PX works like im hoping it will I will go back to the L/R. I am running everthing in Stereo. 1.I would like some suggestions on this if for one do I need a Driverack?
2.If so,which one? PX,PA+,260?
I hope I have given enough info here to set me in the right direction.
Thanks!!
Thanks!!
The DRPA+ has a significant upgrade in the tool set, and sounds better, is faster, and it offers access to the RTA in realtime...
You would need the measurement mic though to get the full benefit of the Driverack...
Thanks Gadget!!
PX- stripped down tier and marketed to the least experienced (and gullable) users.
PA (+) - 1st tier (2nd overall) for those wanting easy operation but still be able to get their hands dirty and money still plays a pretty big role in choice.
260 - Lowest level DR for someone that doesn't mind spending money for a real tool. At only $200 or so more than a PA+, the 260 is 10 times the tool. First level that is designed to be 2 independent mixes and capable of multiple delays and/or zones. Also add GUI computer control. That is worth the price jump alone.
4800 - highest level. Gadget has one. Still making payments I bet. Out of my range. PX and 4800 should never be mentioned in the same sentance.
I bought a PA (not +) back in 2006. Although I was happy, I was not content and immediately started putting money back for a 260 and about a year later I bought the 260. Moved the PA to monitor duty.
2 years ago I went mono and moved monitors (I only use one mix) to the other side of the 260. So on my 260 I have FOH, Monitors, a sepate monitor cue for mix position that I can just hit the mute on or off, and delay fills. Still have an output unused.
The cost difference between the PA+ and the 260 is small considering what you get in return. The learning curve on the 260 (in my opinion is less on the 260) because you (if you use the GUI) can see the effect you have in real time.
Make sure you avail yourself of the GUI, The FAQ section and the Start here thread:
http://www.dbxpro.com/Software.php
viewforum.php?f=60
viewtopic.php?f=61&t=959
The GUI will allow you to program the 260 far easier and quicker, and see visually what your doing, and you can set up a program and then import it into the driverack. You can also export all your modified presets to your computer for safekeeping, and or sending and receiving with others... like if I had a file on the speakers you use I could send you it (.dwp file) and you could import it to your 260....very cool!
The Start here thread takes you through a setup procedure from start to finish, and the FAQ section has lots of tips and techniques for sound reinforcement, and general driverack techniques...
I don't have my 260 yet, but what would the numbers be on the Driverack for my Speakers?
NX55P Tops and LS720P (NX720P) same Subs.
Im studing this out and trying to make heads or tails out of of this. This is a whole new world of running sound.
I also see the DRPA+ has my speakers listed, is this something that would save me a lot of time by getting the DRPA+?
Thanks!!
The setup is relatively easy until you start getting into bi-amped speakers...I would suggest getting the GUI, setting up a custom system and you will gain knowledge in the process the GUI can be found here:
For your system, for us to give you a better setup, you would have to provide amp info...but a good starting point is...
Set the HPF for the sub @ the 3dB down point using a BW18 filter type
Set the LPF for the sub @ 100 hz LR24
Set the HPF for the tops @ the same as the LPF for the subs (100hz LR24)
Then read and do the things in the "start here" thread:
and then peruse the FAQ section for more specific information on a wide variety of subjects:
viewforum.php?f=60
Those speakers are all self powered.
As soon as my 260 gets here I will try thoses settings.
I have downloaded the GUI allready, will order the cables also.
I take it that using the USB adapter will not allow me to use the snake?
I have to use the port?
Gadget, you got a quick reference location?
Just asking.
