Confidence in Auto EQ results?
When I first set up my PA system I ran auto EQ on my speakers and monitors outdoors. What I noticed then was that it always took a long time for auto EQ to finish, and the results were not always consistent for repeated runs. I didn't have access to a quiet outside area for this, so that may have been part of the problem.
Rerunning auto EQ this week in a small (120 sq ft) room with the ref mic at floor level gives different results than the original runs. Auto EQ finishes relatively quickly and the results are pretty consistent from run to run. Is it worth the effort to rerun auto EQ in a larger room (e.g. clean out the garage...) or are room effects totally eliminated by this method?
My ears seem to tell me that the Auto EQ settings improve the sound, but I'm wondering if there is any objective way to confirm that I am making valid measurements. The inconsistency between methods is a concern, as is the fact that the results are significantly outside the manufacturers' specs for these speakers. The Yorkville NX550P speakers test out much flatter than the RCF ART 310A speakers even though, by reputation, it should be the other way around.
Any thoughts?
Any thoughts?
Outdoor Auto needs REALLY wide open QUIET (no I'm not yelling
Remember even under the best circumstances the RTA based Auto EQ is a flawed process and each adjustment should be viewed with skepticism.. and just remember that your ears are the final say...what sounds good.. id good..
I think I have the Auto EQ bug out of my system now.
Thanks-
Lynn
I have to tell you that there really isn't a LARGE community here like the PSW... we are a few dedicated individuals that try and mitigate the hype that comes out with the products...No Auto Eq isn't the hook it up, auto eq (who cares how you do it) and you get audio nirvana... every time... no it isn't even close, but the fact is, if you have NO experience, have NO idea what your doing... you can get closer to what your looking for, or you can at least start to learn what to look for and what the problems are...
The JBL system is just a different algorithm that still relies on RTA (frequency dependent volume information) to try and achieve a target product...As the guys on PSW told you, and I alluded to... some FFT measurement platform and a HUGE learning curve... are the only way to truly get the results your looking for. It may be that you need to just hire someone to tune the system for you...
Otherwise, launch yourself on a course that leads you to an intense learning curve, and the purchase of a minimum of software and equipment, but be prepared to attend lots of classes in order to get the best results with the hugely deep subject of system tuning...
The first thing that these tuning systems doesn't take into consideration is time alignment...or driver alignment within a given speaker...or any number of other factors that affect the sound coming from your speakers. Take ANY speaker that uses a woofer and a horn... and multiply the problems as the number of components increases... UNLESS they are all INSIDE the horn and time aligned like the Danley sound synergy horns do...then the sound source is basically a point source...and many of the problems associated with conventional systems and their deployment are no longer a problem.
Anyway, as the others at the PSW said... RTA based systems are not the answer...
Mike Kovack did a Auto EQ versus SMAART comparison, and within the boundaries of proper setup, the Auto EQ did provide "usable", repeatable results as long as a similar, common practices are utilized... those results are located in the old forum:
http://www.driverack.com/drug/index.asp
Where much of the groundwork for the techniques we use have been formulated...
Actually now that I think about it I moved it here...
viewtopic.php?f=60&t=957
In the FAQ section...
Well let us know if there's anything else we can do for you..
Thanks again,
Lynn
Jim
Pink noise would be a far more consistant test tone than dynamic music. Save the reference song to use after the measuring is complete. You can then listen to a reference song to determine if you analysed the RTA data correctly and made the appropriate EQ changes
No, with the differences in given drivers (even within the same batch), different batches and the like ..my guess is that they went through a LOT of speakers to actually find one that's even close to those specs... or perhaps they "smoothed" the response bumps right out...
Until they start having independent testing of the speakers published specs are no better than no better then ass wipe
Unless you paid BIG bucks for the speakers, or are using Danley products take those specks and throw em right out the window... they mean NOTHING! :shock:
As an example, Mikey, from this forum... illustrious engineer and system designer and tuner was working on an install.. using SMAART to evaluate the setup JBL SRX722... good speakers right? Brand new right out of the box ... here is the actual spec from JBL pro...
Frequency Response : 81 Hz - 20 kHz
(±3 dB)
Mikey couldn't get 12K5 out of the system... there was nothing above 12K in the speakers...curious in further testing there was a BIG difference from cab to cab, so he did a little investigating and found 2 totally different horn drivers in the cabs...even after JBL sent brand new drivers the speakers STILL wouldn't produce ANYTHING above 12,500hz :roll: They were NOT interested in commenting or addressing the issue, and Mikey is a consummate professional.
Needless to say he wasn't impressed with JBL in general...
Dennis and I are also not big JBL fans.. (Or Blose for that matter)
My $.02
Guess I should have said "Don't get me started"
Well..I'll ask another question and hope it won't break the "rules."
While I run MRX/LA400s for my local events..and they think I am "pro" simply because I apply a few basic PA principals and it sounds much better than what they are used to...I have a new situation. Our church has several installers quoting on line array systems for our new building. QSC and JBL are commonly in the specs. One installer now is carrying Meyer. I have always read the threads saying Meyer was an exceptional company. Would that be due to their fixation on quality control?
Appreciate your ever-helpful advice.
Jim
On the other hand you wont find a Ford Focus or Honda Civic in Meyer's product line. They do not offer low or mid budget products. They offer only high end, high price equipment and it is easy to develope a good rep for high quality control when you offer no low end stuff. Example: so I am thinking I should invest in JBL Vertec but then I think to myself JBL JRX doesn't sound great, how much better does Vertec sound...................Of course Vertec sounds fine but JRX does not help sell it.
Dennis
Also, most reputable companies will "demo" a system for you (especially a line array) so you can see if it's going to fit the project. A good acoustician should be employed first to determine potential problems from the start.(especially in cases of lively, or difficult rooms. In some cases pattern control is the ONLY available "acceptable" solution... in that case, the speakers available are very few and far between...(have them look at Danley sound for instance)
Sorry if were making life difficult for you...were only attempting to dispel the myths, and improve the sound... one sound person at a time
Are you saying we suck because we make you think?
When you get some screen shots of the installers prediction software for your church, post them here so that we can share more opinions.
Dennis
