Home dbx User Forum dbx Archive Threads DriveRack PX
px configuration with the new 515xt
h1134h1134 Posts: 2
edited February 2011 in DriveRack PX
hi
i worked with my px and the eon 15 g2 it was great .
i upgrade my speakers to the new eon 515xt and i need help to tune them with my px since there is no preset to them.
it would be great if someone help me to tune them without using the auto eq wizard i want to tune the eq manually/
pls. explain me step by step how to do it
many thanks
shlomi
  • DraDra Posts: 3,777
    Use the preset you used for the 15G2's. Adjust as needed.
    Sent: Thu Feb 24, 2011 12:07 pm
    View message
    h1134
    Message subject: Re: px configuration with the new 515xtFolder: Inbox
    hi
    thanks for your answer
    thats what i thought i should do , but can you help me how to do the changes inside after i chose the eon 15g2 preset?
    the new eon is a little bit wider in frequenceis it goes down to 36 hz and up to 20khz how can i adjust it while i am playing a cd and try to find the best for me?
    thanks
    shlomi
    Sent: Thu Feb 24, 2011 1:08 pm
    View message
    Dra
    Message subject: Re: px configuration with the new 515xtFolder: Sent messages
    Actually, the -10db point is 39hz, but that is useless to you because the speaker cannot reproduce that (that you can hear anyways). The -3db point is more useful information. 42hz, the same as the 15G2. The only gain is the 515XT extends to 18K (from 17k on the 15G2). Very little content above 16K, so again, useless. Whatever settings you had come to for the 15G2's, use those. That is what I meant by using the preset for the 15G2's... same filters and EQ, then tweek to your ears.
    I do not have a PX, so it is hard for me to help you with a button by button explanation.
    again many thanks for your help
    what about the crossover at the old eon is 15 khz and at the new one is 17 khz do i need to change ir?
    if yes do you know how?
    shlomi
    Gadget??
  • GadgetGadget Posts: 4,915
    no... there is no crossover @ 15khz or 17khz... those are simply where the speaker runs out of capability.
    The PX doesn't have an LPF on the high outs anyway so as Dra said use the presets for the Eon G2's... and be done with it.
    As for the equalizer part there isn't any way for us to know because we don't have the Eons...
    gadget
