Question about "System Setup and Gain Structure"
In Appendix A of the DriveRack PA manual, there are instructions for setting up amplifiers for maximum gain structure using the clip indicators of the console and of the amplifiers.
Will the described procedure work if our speakers are not among those available in the DriveRack configuration (we used Custom here)? The amplifiers are available.
Since the speakers were not available for selection, and the DriveRack doesn't know what speakers we are using, would it be better to take the DriveRack out (connect soundboard directly to amplifiers) to adjust the input attenuators of the amplifier, and then put the DriveRack back in and adjust the DriveRack gains with the Xover settings?
Maybe I'm not understanding something (sorry)...
Thanks. -bg
Thanks. -bg
Detailed instructions.
So if we follow this procedure and set the gains on the soundboard, the amplifiers, and the DriveRack as suggested, and we find that the sound volume coming out of the PA system is way too loud, where (at what piece of equipment -- in the DriveRack or at the amplifier) do we back it down?
There are other ways to do the gain structure and you can make it your life's work, but this method has given good results with the least headaches. For digital mixing consoles there is a different path, but there you don't have to worry so much about signal to noise as you do clipping.
Thanks, guys! -bg
Thanks!
