"Y" mic cables
I just got back from a gig involving a student orchestra. I had massive problems getting enough gain from the string section to be suitably audible during the the pp sections. We had 2 mics on each section...Violins, Violas & Cellos. The rest of the orchestra (woodwinds, brass & percussion) was fine.
We started out with the mics set as AB overheads, but got next to no level. We then lowered them down as close as practical to the stronger members of the sections.
I got through the gig reasonably well as long as I was given decent level from stage. Spelt the whole time on a knife edge, just below feedback.
In total I had 16 open mics on stage, all cranked.
The guy that owns the gear wanted me to use some "mic combiner leads" (2 x XLR F to 1 x XLR M). I said no, we should be fine without them..
I have never used these leads before and am not sure they are a good idea. What is the resulting output impedance of the combined mics and what impact will that have on driving the pre's on the desk?
I honestly don't think more mics would have helped, I was just not getting enough level into the mics I had.
Full size orchestra & a 16 channel Spirit desk + operator who has never done an orchestra before........ we did all right....
That's why when 2 mics are used in proximity you often find them in X/Y configurations, MS configs and other near coincident pairs instead of open faced spaced mics.
What mics were used? The pickup pattern can exacerbate proximity issues...
A simple Google keyword search should start you finding out about coincident mic cancellations and orchestra micing techniques. I'll see if I can't dig something up if I get time, but the weekends are usually balls to the wall for me...
I should have mentioned that this was an outdoor gig...
The mics were a mixed bag of 57s, a couple of Beyer mc 930s, some cheapo Australian Monitor pencils, and a few cheap Shures.. Dynamics were used on the brass and woodwinds and the condensors on the strings.
One of the problems I have with google is that information found is often either incorrect or commercially biast... I'd rather hear from those I can be confident actually know!
Cheers
Oh... Any other comments on "Y" combiners? Are they a no no or do they have their place? Do they cause impedence problems?
The wye cable may not be the correct call for your application but you won't know until you try.
Dennis
Sounds like you need some super cardioid mics and if thats not possible your stuck with what you have... adding a whole bunch more mics (unless they are MUCH closer) isn't going to make things any better, and wye cables will make a MESS of things...
P.S. you could ask @ the PSW... they are ïn the know... but expect kinda what I said.. i monitor the site all the time and learn just like everyone else...
I'm starting to think the only problem we had was extremely quiet source material. Student string players , outside and nervous. I did notice that we were getting audible chair creaking and general stage noise spill...
Are you thinking super cardioid in the context of cancelations? (less spill - less interaction?)
I think your right.. it's a no win cituation :?
Before we have to do it again I'll re-examine the entire approach.
Next week is a big band... Maybe we'll have the 260 by then. Hope so..
My next question is, how to mic up a big band. I know I should post this stuff on PSW, but I find that place a little condescending. Having two different forums, one for the "pros" and one for the rest of us alienates me..
The "stage" is a flat bit of gravel next to a small dam. The audience is separated from the stage by the water and are about 75 meters away. I'll take a photo and post it.. Strange place for a gig..
I ran into the client in a cafe yesterday... Told him what I thought of his requirement for placement of the stacks. He replied with slimy diplomacy....
I'll have a stage plot tomorrow...
Dennis
Conventional 2 x stacks. 1 S410 on each side with 2 x 408 stacked on each.
The audiene is also sitting on a hill with the lowest point lower than the stage and the highest higher than the stack.
Vertical coverage isn't too bad, although the top of the hill is lacking. Horizontal coverage is pretty crap. The S408 has a 75 deg H dispersion, which really doesn't cut it. Especially when we are forced to place the stacks too close togeather.
This week I'm trying to get us there earlier to try the S408 arrayed side by side. We will then have 150 deg a side. I'm hoping this will provide better coupling and give us some better projection too.
Any thoughts? Anyone?
